Results 1 to 9 of 9
Like Tree9Likes
  • 1 Post By Twiceroadsfool
  • 1 Post By Scott D Davis
  • 1 Post By elton williams
  • 4 Post By MPwuzhere
  • 2 Post By Scott D Davis
Thread: BIM360 Design with wider team
    Moderator Drew's Avatar
    December 9, 2010
    Perth, Western Australia
    689
    08:09 PM
    Hi all,
    We have used the C4R and A360 teams on previous projects and it seemed to work well. Moving forward to the new BIM360 Design platform i was wondering how this works with teams that do not have or do not want to obtain a license? This could be because their time is limited on the project or that they simply dont want to pay the cost, whatever, some teams just wont be a part of the new platform / workflow.
    In the old system you could upload a file from non team members and have the wider team see them. is this still the case in the new platform? If so is there any documentation around?
    Cheers
    10,127
    07:09 AM
    No documentation needed. Just means someone who DOES have a license has to periodically upload the other consultants model. So the architecture team (on bim360) can upload the lighting consultants (not on bim360) model, as an architecture model.
    It's just extra work for the architecture team to do it.
    cganiere likes this.
    December 9, 2010
    689
    08:09 PM
    Thanks Aaron,
    So its a similar process as previous.
    Autodesk Scott D Davis's Avatar
    March 5, 2011
    Southern California
    653
    05:09 AM
    Quote Originally Posted by Drew View Post
    Thanks Aaron,
    Revit 2019.2 also has a new feature/capability called Revit Cloud Model
    Revit Cloud Model
    Allows a non-workshared local model to be saved directly to a BIM 360 project, which can then be linked to other Revit projects via BIM 360. You only need a BIM 360 Docs license to do this, instead of the more expensive BIM 360 Design license needed to make a Cloud-workshared Revit model.
    This also works for Revit LT 2019.2 and later. You can get it here on a 30-Day trial:
    https://www.autodesk.com/bim-360/pla...ment-software/
    After that, It's less than $7 (US) per week per user for BIM 360 Docs. For about another $10 (US) - $17 per week, you can get BIM 360 Design...
    tidalwave1 likes this.
    February 1, 2011
    United Kingdom
    98
    01:09 PM
    Hi All,
    Is there any standard (Autodesk issued) IT architecture setup guide for BIM 360 design setup for a large project with large teams? Mainly like bandwidth per user, internet speed etc. If so, I would appreciate if you can point me to the guide.
    Gold Coast
    2,609
    10:09 PM
    Quote Originally Posted by pfaudler View Post
    Hi All,
    I doudt you'll get anything more than basic how-to's from anyone, for free.
    We had in-office training sessions from an Autodesk certified consultant when we first started with BIM360. Money and time well spent. Setup with project teams is also available. Your reseller should be able to point you in the right direction or you could search https://servicesmarketplace.autodesk.com
    pfaudler likes this.
    Coeur d Alene, ID
    4,744
    05:09 AM
    Like this?
    https://knowledge.autodesk.com/suppo...-360-Docs.html
    https://knowledge.autodesk.com/suppo...-products.html
    https://forums.autodesk.com/t5/bim-3...s/td-p/8228368
    Basically...don't run on dial-up, don't work over wireless, and get the fastest connection you can afford. If you have 15+ people connecting and you have a basic service package for internet, you are probably going to hate life.
    March 5, 2011
    Southern California
    653
    05:09 AM
    Hi All,
    Here's a link to the Getting Started Guide for BIM 360 Design:
    https://knowledge.autodesk.com/suppo...g-Started.html
    Also, there is a Webinar on Tuesday March 12, 2019 at 1pm EST that is titled “BIM 360 Design for Advanced User" You could ask these types of questions to the presenters. Register here: https://autode.sk/2TiUZWT
    pfaudler and tidalwave1 like this.
    February 1, 2011
    United Kingdom
    98
    01:09 PM
    Thank you all for your responses. Thanks Scott for sharing the webinar link..will definitely connect and ask this query.
    However, it would great to have a std IT architecture setup guide/recommendation published by Autodesk. Currently we have a large project with 40+ concurrent users working Revit files in the cloud and as Michael says above...people hate life at work!!!
  1. Revit 2018.3.1 update generating Dynamo & BIM360 Design errors
    By nharburger in forum Architecture and General Revit Questions
    Last Post: July 19th, 2018, 03:13 PM
  2. Replies: 0
    Last Post: April 30th, 2018, 11:15 AM
  3. Replies: 0
    Last Post: December 12th, 2016, 05:15 AM
  4. Replies: 0
    Last Post: October 5th, 2016, 12:45 PM
  5. REVIT software rollout - wider team engagement
    By Jimmy_D_69 in forum Worksharing, Revit Server & C4R
    Last Post: March 4th, 2014, 07:47 AM
