Results 1 to 3 of 3
Thread: [need help] revit server on vps
    June 6, 2016
    24
    04:58 PM
    I just setting up a Revit Server run on Amazon EC2 Instance. Everything had done: IIS, RSN.ini
    But i still can't connect it to save central file. Are there anything i need to do? Please help me!
    Thanks a lot!
    Attached Thumbnails Attached Thumbnails [need help] revit server on vps-capturea.png   [need help] revit server on vps-capturea.png
    Member Markus's Avatar
    July 27, 2012
    Seattle, WA, United States of America
    331
    01:58 AM
    do you have the firewall ports 80 and 808 open?
    June 6, 2016
    24
    04:58 PM
    Quote Originally Posted by Markus View Post
    I just leave it default, everything work fine.
  1. how to connect Accelerator Server with Revit Host Server ?
    By usmanali41 in forum Worksharing, Revit Server & C4R
    Last Post: May 16th, 2017, 02:27 PM
  2. Replies: 0
    Last Post: May 5th, 2017, 07:55 PM
  3. Replies: 11
    Last Post: April 22nd, 2014, 08:09 PM
  4. Revit Server Internal Error when trying to connect to another server
    By jespinoza in forum Worksharing, Revit Server & C4R
    Last Post: July 2nd, 2012, 10:37 PM
  5. Revit Server - how many central servers can a local server serve?
    By kingjosiah in forum Worksharing, Revit Server & C4R
    Last Post: March 8th, 2011, 05:12 PM
Tags for this Thread
