Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: BIM 360 Design & DWG Links
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    3,021
    06:19 AM
    I'm using BIM 360 Design (not C4R) in Revit 2018.3.1
    I've got a DWG link that I uploaded to the same folder in BIM 360 Docs
    The DWG was originally located on our network drive, and that's what the path still says, so of course I'm getting a "File not found" error.
    Here's my problem: When I go to Manage Links, I can see my BIM 360 drive under the Revit Links, but I don't have that drive under the CAD Formats tab.
    So, how do I repath my DWG?
    10,362
    06:19 AM
    Im not 100% certain, but i thought you had to do it through Desktop Connector? Or did they change it?
    January 10, 2011
    St Paul, MN
    3,021
    06:19 AM
    I have Desktop Connector installed, but I'm not sure it's working right.
    It doesn't start on boot. I have to start it manually, and half the time when I start it, I get the Event Viewer popping up.
    Member Markus's Avatar
    July 27, 2012
    Seattle, WA, United States of America
    334
    04:19 AM
    Did you install the latest version 6.1.0.667? If you installed an earlier version, one must install two programs: Desktop Connector 6.0 and the BIM 360 plugin B360provider.exe.
    January 10, 2011
    St Paul, MN
    3,021
    06:19 AM
    Yup. I've got 6.1.0.667 installed.
    I've also noticed that it's pretty bad at shutting down.
    Seems to often take a long time, or never close at system shutdown
    July 27, 2012
    334
    04:19 AM
    Forgive me for asking the obvious, but you already have access to the new BIM 360 hub? I installed the Connector on our Citrix servers, and had difficulty with one server. Connector would crash whenever it tried to load. Autodesk was able to resolve it - my Windows Profile was at fault. I don't think this applies to your case; however I wonder if it will work on a different computer?
    January 10, 2011
    St Paul, MN
    3,021
    06:19 AM
    Two months (and a couple of versions) later I just stumbled across my old post.
    We're now on Desktop Connector 6.3.0.692 and things seems to be working much better.
    Coeur d Alene, ID
    4,817
    04:19 AM
    Hey Dave...so are you able to link in a DWG that is on the BIM 360 drive? If so...what did you do? I can see the dwg's via the desktop connector in explorer but nothing when I try to link a DWG file from Revit. If I have to download the files and work locally BIM 360...well...it s$#ks.
    Revit Import/Link shows the External Reference Cloud connection....but nothing on the CAD side. :/
    Coeur d Alene, ID
    4,817
    04:19 AM
    Okay...got it to work. Turns out our IT guy disabled Network Discovery on all our workstations. So I had to drag and drop our BIM 360 share folder to my desktop so Revit could see it.
    10,362
    06:19 AM
    Good to know. Tons of offices disable Network Discovery.
    Aaron Maller
    Director
    Parallax Team, Inc.
  1. Replies: 0
    Last Post: April 7th, 2017, 12:45 AM
  2. schedule links and design options
    By elton williams in forum Architecture and General Revit Questions
    Last Post: November 14th, 2013, 08:18 PM
  3. Case Design Inc Addins - Delete All Views, Sheets and Links.
    By ThatBIMGuy in forum Third party Add-Ins, API and R&D
    Last Post: June 5th, 2013, 11:46 PM
  4. Replies: 0
    Last Post: April 13th, 2012, 01:15 AM
  5. Replies: 0
