Results 1 to 1 of 1
Like Tree2Likes
  • 2 Post By IvanPajares
Thread: Revit Server Backup Script
    July 14, 2015
    Madrid
    13
    04:15 PM
    Hi group,
    I have completed and tested a python 3 script to backup models in revit server instances in the LAN.
    The github page for it is: https://github.com/ivanpajares/revitbak
    The code is commented in spanish only but I plan to translate the comments sometime in the future...
    The script calls RevitServerTool for each project in the server instance to be backed up and preserves the folder structure within the server.
    It requires configuration in opciones.py of project codes and folders for it to work (so it knows where to dump the files to).
    Other data needed for admin emails, logging, etc., can be configured also.
    I have been using it for a couple of months now and it works flawlessly allowing periodical backups of the file with windows task scheduler.
    I am not too familiar with github yet so any comments here are welcome!
    Regards
    Twiceroadsfool and duongduyb like this.
  1. how to connect Accelerator Server with Revit Host Server ?
    By usmanali41 in forum Worksharing, Revit Server & C4R
    Last Post: May 16th, 2017, 02:27 PM
  2. Replies: 11
    Last Post: April 22nd, 2014, 08:09 PM
  3. Revit Server Internal Error when trying to connect to another server
    By jespinoza in forum Worksharing, Revit Server & C4R
    Last Post: July 2nd, 2012, 10:37 PM
  4. Revit Server on Windows Server 2008 R2 Foundation
    By David Thigpen in forum Worksharing, Revit Server & C4R
    Last Post: May 1st, 2011, 08:21 PM
  5. Revit Server - how many central servers can a local server serve?
    By kingjosiah in forum Worksharing, Revit Server & C4R
    Last Post: March 8th, 2011, 05:12 PM
