Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Can't Manage C4R projects?
    jmk
    jmk is offline
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,292
    10:30 PM
    Is anyone else having problems managing their C4R models? For several days whenever my coworker or I have tried to access the "Manage A360 models" button (2017.0.3) the message "A360 projects that contain A360 models cannot be retrieved at this time. Please try again later." appears. I could understand it being flaky when trying around the time either C4R or Bim 360 was down or degraded, but they aren't now, and we need to get models published.
    I've tried opening the Manage A360 models dialog with and without a project opening, after signing out, restarting Revit and resigning in - no changes. I have sent a comment to Autodesk through the health dashboard dialog.
    Attached Thumbnails Attached Thumbnails Can't Manage C4R projects?-manage-a360.png
    Autodesk
    (Product Line Manager, BDS)
    Kyle's Avatar
    April 3, 2012
    227
    01:30 AM
    Sorry about that. We've seen this happen when the version of Revit 2016 is newer than the corresponding C4R code that's installed. What's confusing is that you list 2017 as the version, which includes the corresponding C4R addon update as part of the install. My working theory is that you guys might have gotten a deployment of a Revit update, but not the corresponding C4R addon. Easiest solution, assuming you are at liberty to install updates, would be to install Revit 2017.1, which will fix the mistmatch + get you running on the latest, most stable code.
    -Kyle
    jmk
    jmk is offline
    December 31, 2012
    NM, USA
    1,292
    10:30 PM
    We're small enough that we don't deploy, and the projects we're trying to update are Revit 2017. When 2017.1 came out it seemed that people were having issues with cloud models, so I was holding off on updating until those issue shook out. If I update my version to 2017.1 to test will it cause problems for anyone on 2017 if we're working on it in different versions? I'd like to test it before having everyone else update.
    Autodesk
    Kyle's Avatar
    April 3, 2012
    227
    01:30 AM
    As a general rule, working across update versions in C4R isn't a problem. In this case, however, the 2017.1 update does change branding to BIM 360 Team, which updates the file path saved in Revit. We've seen side-by-side issues that arise as a result, so I wouldn't recommend it unless everybody moves forward.
    If you still have the installer for your update kicking around (probably in C:\Autodesk) then try to re-run it. That should make sure the right C4R addon code is installed.
    -Kyle
    jmk
    jmk is offline
    December 31, 2012
    NM, USA
    1,292
    10:30 PM
    Will the same thing cause a problem for consultants linking in the models, or just people working in the same model? I can upgrade everyone in the office in the same time span, but our consultants probably can't, at least for all projects.
    I removed and reinstalled both collaboration for 2016 and 2017, but I still can't manage models.
    Autodesk
    Kyle's Avatar
    April 3, 2012
    227
    01:30 AM
    Nope, it won't. It should just be for the team members working directly on the models.
    -Kyle
    jmk
    jmk is offline
    December 31, 2012
    NM, USA
    1,292
    10:30 PM
    I tried installing 2017.1, but the only download is for 2017.1.1 Fixes, and trying to install that gives this error message "The upgrade cannot be installed by the Windows Installer service because the program to be upgraded may be missing, or the upgrade may update a different version of the program. Verify that the program to be upgraded exists on your computer and that you have the correct upgrade." I can't find a 2017.1 to install first, so I'm not sure what the problem would be (I am an admin on my computer and have admin rights)
    Rotterdam, South Holland
    2,943
    06:30 AM
    jmk, do you have SP2 installed? I THINK 2017.1 and 2017.1.1 both require SP2, which is non subscription. 2017.1 has been superseded, as it had "issues".
    jmk
    jmk is offline
    December 31, 2012
    NM, USA
    1,292
    10:30 PM
    As far as I can tell I have sp 2 installed, I think I remember doing it and the version number is post sp 2. It certainly doesn't appear in the desktop updater.
    I assumed that if 2017.1 was broken any links to download it would be replaced by 2017.1.1, so I was surprised when it didn't work.
    jmk
    jmk is offline
    December 31, 2012
    NM, USA
    1,292
    10:30 PM
    I did have both service packs as well as the latest security fix. I had to uninstall Revit 2017 entirely, then was able to upgrade straight to 17.1.1. Now cloud worksharing works. I suspect something in the 17.0.3 security fix is causing the 17.1.1 update to fail. I was able to update a user who only had sp 1 installed without issue, but it has failed on every computer with the 17.03 update.
    Update:
    Every user I have tired to upgrade that has no service packs, sp1 or sp2 can be updated directly 2017.1.1. Any user that has the security fix .03 I have to completely uninstall Revit 2017, reinstall it, and then update to 2017.1.1 without doing the service pack/security fix bundle.
    Last edited by jmk; January 13th, 2017 at 04:34 PM. Reason: Additional information
  1. Manage Links & Manage Worksets
    By cmille10 in forum Architecture and General Revit Questions
    Last Post: September 25th, 2014, 10:20 AM
  2. Replies: 0
    Last Post: August 28th, 2012, 02:15 AM
  3. Replies: 0
    Last Post: August 22nd, 2012, 04:45 AM
  4. Manage documents (PLM) for AEC
    By PepaR in forum Architecture and General Revit Questions
    Last Post: December 20th, 2011, 12:21 PM
  5. Manage Images
    By DaveP in forum Architecture and General Revit Questions
    Last Post: March 1st, 2011, 08:13 AM
Tags for this Thread
