Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: Documenting the Revit Template
    Member kpcarch's Avatar
    March 16, 2012
    Seattle, WA
    70
    01:51 PM
    Our templates have become larger and larger. Does anyone have any tips to properly document what is in the template? Ways to output relevant info to excel or a database? When we rebuilt our template for 2013 we found it difficult to systematically re-build all the features of our 2012 template. I envision some kind of checklist, but am not sure of which approach to use. If I could export the whole thing to an excel sheet or database, I could then edit out unnecessary info and build a document that way, or, I could print out every page, type property, family.......and document the template manually/visually (this seems like it would take longer that building the template).
    Any ideas?
    Thx,
    Kevin
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,141
    04:51 PM
    Ideate has a couple tools that might work, although they are pricey.
    Ideate Explorer
    There are also some spreadsheets floating around that people have created:
    http://www.revitforum.org/architectu...anagement.html
    http://www.revitforum.org/tutorials-...ct-styles.html
    They would still mean some legwork but at least the spreadsheet is already setup.
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    08:51 PM
    I use Evernote for it... Easy to share, easy to set up. Simply made a note per item (used Aaron's template for building a template (), and then added some of my own to it.
    I attached all documents (sp-file, keyboard shortcuts, customized revit ini, excelsheet with all possible customisations, and so on and so forth).
    And yes, it will take longer to setup then the actual template. But imho a template is more then object styles...
    10,188
    03:51 PM
    Mine is a Word document. Which is also Copied and Pasted in to a drafting view IN the template. That way you can tell what version someone had WHEN they started the project.... 6 months after the fact. Simple and effective.
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    08:51 PM
    Unless some douche deletes it...lol
    That would be one hell of a drafting view btw. I do have a version number, but it's part of my preloaded titleblock as an invisible parameter with a link to the corresponding template description
    United States
    1,144
    02:51 PM
    I agree with mdradvies on this too. Having this as a drafting view makes it susceptible to purging and deletion. I added a project parameter to Project Information in my template for both my template version and for my reference detail version. I have only recently added this for 2013, so I am not sure how this works in practice yet...but in theory I like it!!
    August 9, 2011
    Louisville, KY
    6,141
    04:51 PM
    Quote Originally Posted by gdoherty0102 View Post
    I've got a parameter for template version but as of yet do not have a document with changes made. The versioning works well, although it would work better if I had changes noted. I need to do that...
    10,188
    03:51 PM
    Worrying about deleting exists for both: A drafting view and a piece of Project Information (Project Parameter). Sure, we could have the discussion of "whats easier to delete," but at the end of the day, theyre both in a place that shouldnt be getting deleted regardless.
    Ive had it this way for3.5 years now, and i think its only been deleted once.
    Project parameter works too, as long as you have a list somewhere ELSE of what it relates to...
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    08:51 PM
    Just to be clear: I didn't use a parameter BECAUSE it would be easier to delete. I use a parameter because it seemed the easiest and cleanest at the time.
    March 16, 2012
    Seattle, WA
    70
    01:51 PM
    Hey! Thanks for the great replies. A couple questions:
    1. to: mdravies: What is an sp-file? "(I attached all documents (sp-file, keyboard shortcuts, customized revit ini, excelsheet with all possible customisations, and so on and so forth)"
    2. to: twiceroadsfool: how much granularity is there in your word doc? such as all items in the .xls for object styles as mention by mdravies? Also, do you add workflow descriptions to a detail view also?
    Thanks again.
  1. Building a Revit Template
    By Twiceroadsfool in forum Tutorials, Tips & Tricks
    Last Post: January 31st, 2019, 07:31 PM
  2. help in revit 2013 (template problem)
    By orass in forum Structure - General Questions
    Last Post: July 1st, 2013, 07:10 PM
  3. Losing objects when I bind a Revit link in my template
    By Devlin in forum Architecture and General Revit Questions
    Last Post: November 1st, 2011, 08:37 PM
  4. how i can reset revit template ?
    Last Post: September 28th, 2011, 02:28 PM
  5. Inside the System: Documenting Multi-Section Panels
    By Inside the System in forum Blog Feeds
    Last Post: September 12th, 2011, 01:20 PM
