Results 1 to 5 of 5
Thread: Grids shown on different levels tip
    March 8, 2011
    Philippines
    10
    08:24 PM
    hi guys,
    just a tip for the newbies...
    when we start a project basically we need the grid lines or grids.
    usually we do the 'grids' on a single level and have it shown on other levels. but sometimes we encounter that the entire grids don't appear in the other levels, what I usually do is make a section, check if the vertical or horizontal(level/elevation) grids are intersecting...if not then do the stretching on the grids to make it intersect or cross other grids...
    hope this will be a good help to the newbies...not those on experts...
    happy reviting...
    July 30, 2011
    1
    01:24 PM
    thanks..! I was just looking for it
    Gold Coast
    2,524
    10:24 PM
    This is a good tip jaypro, one thing not immediately understood by many people new to revit is how to control extents for grids & elevations.
    Revit Guru
    July 28, 2011
    Brisbane, Australia
    49
    10:24 PM
    Best to use a "scope box" to control all your datums (levels, Grids, Overall Elevations/sections/Plans) Create a scope box that encompasses the extent of your model - give a useful name. Then select all your datums and in their instance properties set their scope box to use this. You can associate views with your scope box as well. This is great for extending the size of your building as a lot of things can get updated automatically.
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    12:24 PM
    remember though that there is a difference between 2D and 3D view. If you select a Grid (or a Level for that matter), both sides will show a small text in blue reading "2D" or "3D". Clicking it toggles the value between the two. If you toggle it to 2D it will only change the extents IN THIS VIEW. Toggling it to 3D changes the extents IN THE ENTIRE MODEL.
  1. Grids in 3D
    By lucis29 in forum Architecture and General Revit Questions
    Last Post: April 29th, 2011, 07:32 PM
  2. Dead Levels
    By redmonki in forum Architecture and General Revit Questions
    Last Post: March 28th, 2011, 12:57 PM
  3. Grids
    Last Post: February 26th, 2011, 11:57 PM
  4. Copy and Paste Text Tip
    By dzatto in forum Tutorials, Tips & Tricks
    Last Post: February 25th, 2011, 10:11 AM
  5. Doors shown closed in reflected ceiling plans?
    Last Post: February 7th, 2011, 11:42 PM
