Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Like Tree4Likes
Thread: Revit's Default Object Styles
    May 17, 2012
    Halifax, Nova Scotia
    44
    11:18 PM
    I'm in the process of making spreadsheets in open office that are the default object styles in RST 2013. I'm not sure if they're the same in Architecture but if they are have at it.
    I'm doing this as an editable spreadsheet for those who want to keep a physical record of the object styles and line weights they use around the office and who don't have the ability to export it directly from Revit.
    I'm including both the PDF's and the xls files, and I'll upload them as I finish them.
    EDIT: That's all of the defaults. If anyone knows how to make PDFs editable in an easy way, let me know and I'll update the PDF versions.
    PDF Versions are in a later post.
    Attached Files Attached Files
    Last edited by Alexander_J_Hicks; June 15th, 2012 at 02:27 PM. Reason: Noticed I missed Fire Alarm Systems in the annotations and added a Disciplines column to it as well.
    December 21, 2010
    C.LONDON
    4,330
    02:18 AM
    I opened the .pdf purely out of curiosity (I've done ours) and have only one thing to say.
    You may well wish to revise your pen choices. Pen 1, by default, is assigned for pattern fill lineweights, and Pen 2, by default, is assigned to pattern fill lineweight of (something else I can't remember). To articulate your lineweights separate to those - your lowest/thinnest lineweight (typically thinner than hatch patterns) will then therefore be Pen 3.
    May 17, 2012
    44
    11:18 PM
    Those are defaults in the program. I have mine set for my office. Filename: Structural_Default_ModelObjects.pdf
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    5,999
    09:18 PM
    Quote Originally Posted by Alexander_J_Hicks View Post
    Did you export everything? If so how?
    I would love a record like that for building a new template but don't have the time to go through each setting and re-type it all.
    May 17, 2012
    44
    11:18 PM
    I didn't export it. I have my object styles open on one moniter and OpenOffice on the other. Time consuming. But, if you use this one you don't have to type EVERYTHING. Just the information.
    December 21, 2010
    C.LONDON
    4,330
    02:18 AM
    I think you misunderstand what I'm getting at - pattern lineweight assignment is hardwired - there's no adjusting them.
    To er on the side of caution I will caveat my post(s) here with the fact that I've not fiddled with lineweights in my template for about a year now, so things could have changed and/or I could be talking out of my aris; but you're effectively using the same pen for patterns as you are for all your categories assigned to Pen 1
    You may want to read THIS and possibly THIS for further expansion on the topic....
    And, I am, of course, only trying to help, and thank you for sharing your content with everyone.
    One thing you may also wish to consider; to expand on your matrix, is the definition of the line styles themselves, within the same table. Unless you maintain a second matrix for all your dot/space/dash lengths?
    May 17, 2012
    44
    11:18 PM
    EDIT: I think my initial post came across rude. I'm sorry :/
    I have mine set up like that, these are just the OOTB object styles.
    And, no problem. I figure if I'm going to be on this forum I may as well contribute.
    August 9, 2011
    Louisville, KY
    5,999
    09:18 PM
    I second what snowy said.
    Thanks for the files!
    December 21, 2010
    C.LONDON
    4,330
    02:18 AM
    Trust me mate, despite having a particularly fine complexion for a 30 year old, 20-a-day smoker, my skin is thicker than most. You're going to have to go well out of your way to upset me.
    EDIT Chad spelling my name wrong, however....
    Alexander_J_Hicks likes this.
    August 9, 2011
    Louisville, KY
    5,999
    09:18 PM
    I r smrt.
    it edited out the fruit based sailor reference i tried to use
  1. Purging object style in Revit rvt and rfa
    By Parametric Snowman in forum Architecture and General Revit Questions
    Last Post: May 21st, 2017, 06:22 PM
  2. Default Revit Version
    By Chadwick17 in forum Architecture and General Revit Questions
    Last Post: September 4th, 2013, 03:44 PM
  3. New Line Styles?
    By stl4310 in forum Architecture - Family Creation
    Last Post: December 9th, 2011, 11:32 AM
  4. Revit Detail: 13.8 Modern house - Presentation styles
    By Revit Detail in forum Blog Feeds
    Last Post: September 8th, 2011, 06:30 PM
  5. Object Styles Spreadsheet for Template Management
    By rkitect in forum Architecture and General Revit Questions
    Last Post: April 28th, 2011, 01:48 PM
