Page 1 of 2 12 LastLast
Results 1 to 10 of 20
Like Tree9Likes
Thread: Spot slope annotation for ramps
    Orlando, FL, USA
    3,141
    06:48 AM
    For some reason that we don't know yet , the Spot Slope annotation tool does not work on ramps in plan views. It works on elevation, sections, and 3d views, though; however, it's on the plans where I need it most. Until this is fixed in the future, here's a solution that you might find useful:
    From a 3d view, create a model line with thin line style, aligned and locked to one of the slanted edges of the ramp. (That line is represented in heavy red in the image, for clarity). Then go to the plan view, and try again the Spot Slope annotation tool on the ramp, but this time use the tab key to find the model line. Now you have the slope of the ramp.
    If the slope of the ramp changes, the annotation will update, since the line is locked to the slope of the ramp. The ramp can be edited, shortened, lengthened, and moved, without affecting the slope annotation at all. Only issue I found is that when the ramp is rotated, the constraint is lost, but then it is very easy to align and lock the line to the ramp again, and the Slope annotation goes back in place again, updated.
    Attached Thumbnails Attached Thumbnails Spot slope annotation for ramps-spot-slope-ramp-plan-view.jpg
    St. Louis, MO
    1,954
    05:48 AM
    Nice tip, Alf!
    Autodesk JeffH's Avatar
    December 13, 2010
    The Ivory Tower (Manchester NH)
    782
    06:48 AM
    There is another way that might be even easier than this. You can darw an object in plan that WILL take a spot slope (i.e. a floor with a slope arrow), then use the spot slope tool on that object. Now select the spot slope annotation you just placed on the flooor object and move it to the ramp object. The slope will be reported correctly and change in response to changes made to the ramp object.
    P.S. This trick works for placing a spot elevation annotation on a ramp object in plan as well.
    In added and articel to the wikihelp on this process as well.
    http://wikihelp.autodesk.com/index.p...tions_on_Ramps
    Orlando, FL, USA
    3,141
    06:48 AM
    Quote Originally Posted by JeffH View Post
    ...P.S. This trick works for placing a spot elevation annotation on a ramp object in plan as well.
    Amazing, Jeff. The big question here is why does this task have to be a hidden workaround and not a simple feature?
    A ramp cannot take a spot slope annotation in a simple way, but it can, in an 'indirect' way...
    St. Louis, MO
    1,954
    05:48 AM
    Yep--I agree with Alf. Sounds like a bug in the program.
    December 13, 2010
    782
    06:48 AM
    I don't know the "technical" reasons why it works the way I discovered, it just does. I just happened across this trick last week when a feedback e-mail was sent about adding the ability to place a spot elevation on a ramp in plan. I thought it had something to do with the way 3d geometry was being generated for the ramp object in plan. Turns out that is not the issue. I just stumbled across this "solution" while messing around with things.
    @Cliff - It is an issue that has been logged for some time now.
    Orlando, FL, USA
    3,141
    06:48 AM
    Interesting, Jeff. Well, then, the Factory should fix it. I met with a group of architects some weeks ago, from one of the largest firms here in Miami, and they were very disappointed about Revit ramps. One of their reasons was the fact that they could not apply the spot slope annotation to their ramps in their floor plans; so they were using just text and arrows, with the risk of showing wrong information later if the slope of the ramp changes. Well, it's good to know now that there are at least 2 solutions.
    yoonkou likes this.
    Junior Member engel_hg's Avatar
    October 9, 2011
    Manila,Philippines
    48
    06:48 PM
    Nice got it thanks for the tips guys.
    May 7, 2014
    62
    06:48 AM
    4 years later and it still hasn't been resolved...
    Orlando, FL, USA
    3,141
    06:48 AM
    Quote Originally Posted by theotheranony View Post
    Yes. Just for the sake of it, every year, with every new release, I go ahead and check if they have fixed this. If they didn't, I do like the prisoners in the movies: I draw another vertical line on the wall to count another year, haha...
    But, don't worry. As Jeff says above "It is an issue that has been logged for some time now.".
LinkBacks (?)
  1. February 15th, 2012, 09:10 PM
  1. Spot Slope with no Number
    By Craig Howie in forum Architecture and General Revit Questions
    Last Post: October 31st, 2011, 01:54 PM
  2. Model pattern not visible on ramps in plan views?
    By need4mospd in forum Architecture and General Revit Questions
    Last Post: July 12th, 2011, 10:25 PM
  3. Slab slope discrepancy btw "Slope arrow" and "Define Slope"
    By jh75 in forum Structure - General Questions
    Last Post: May 6th, 2011, 08:39 PM
  4. Ramp spot elevation
    By bangobeat in forum Architecture and General Revit Questions
    Last Post: April 22nd, 2011, 08:44 PM
  5. Spot Elevation Family
    By Elisa in forum Architecture - Family Creation
    Last Post: January 6th, 2011, 10:32 PM
