Page 1 of 11 12345 ... LastLast
Results 1 to 10 of 109
Like Tree75Likes
Thread: Can't see it in the view? Here's 33 reasons maybe why
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,464
    11:31 AM
    I found this somewhere online back when I started using Revit and still find it useful. Hope someone else can use it also.
    Checklist: 33 steps to being able to 'find stuff'
    Check to see if:
    1. The object or category is temporarily hidden
    2. The object or category is hidden in the view
    3. The object is being obscured by another element
    4. The object's category or subcategory is hidden in the view
    5. The object is outside the view's view range
    6. The view's far clip depth is not sufficient to show the object
    7. The object resides on a work set that is not loaded within the project
    8. The object resides on a work set that is not visible in the view
    9. The object resides on a work set that is not loaded in a linked file
    10. The object resides on a work set that is not visible in a linked file
    11. The object resides within a group (detail model) and it has been excluded from the group
    12. The object is part of a design option that is not visible in the view
    13. The object is part of a linked file that is not visible in the view
    14. The object has one or more of its edges overridden to display as '<Invisible lines>'
    15. The object is a family and none of its geometry is set to be visible in the view type
    16. The object is a family and none of its geometry is set to be visible at the view's detail level
    17. The object is set to not be visible at the category's detail level
    18. The element has been placed outside the view's crop region (visible extents)
    19. The element is an annotation object and does not reside entirely within the annotation crop region
    20. The object's phase settings or the view's phase settings prevent the object from displaying in the view
    21. The view's discipline is prohibiting the visibility of the object
    22. The object is affected by a filter applied to the view
    23. The object is subject to an element override, set to background color
    24. The object is subject to a category override, set to background color
    25. The object style is set to background color
    26. The object is constrained to a scope boxes that is not visible in the view
    27. The extents of the object itself don't permit it to be seen
    28. The object is a mass, and 'Show Mass' is turned off
    29. The object's host view has been deleted (area boundaries)
    30. The view's scale is prohibiting the object's visibility
    31. The object is a linked instance with coordinates too great for Revit to handle
    32. The user has incorrectly identified the link instance to which the element belongs
    33. The object is in a link that is not in its correct position
    LeanneZ, kev4174, xtiny and 25 others like this.
    JCM
    JCM is offline
    December 17, 2010
    Pembroke Pines, FL
    571
    03:31 PM
    I think these are great tips! Especially for begginers/intermediate users
    I think its missing item 34. Check to see if you actually drew the object you want to find (Had this happen during a stressful week and excessive amounts of )
    CHintan.thakkar and bjrn like this.
    Orlando, FL, USA
    2,955
    02:31 PM
    Quote Originally Posted by JCM View Post
    That's a good one. The list is unbeatable. I have come twice to this thread to read the list again, thinking that I have discovered something that is missing, and to my surprise, I have found on the list what I was thinking. So I haven't been able to add Item 34 yet.
    United States
    1,136
    01:31 PM
    I agree that there are many different reasons that things can not show up, but really there are only about 5 things maybe a few more but less than 12 that will help you with all of those issues.
    Checking Visibility Graphics (Model, Links, FILTERS)
    View Range
    The light bulb
    Phases
    Worksets
    Design Options
    Mikes65 likes this.
    Member truevis's Avatar
    January 7, 2011
    111
    03:31 PM
    34. Wall is subsumed by automatically-embedded curtain wall
    35. Something is really far away from the middle of the project and when the view is zoomed to fit, everything disappears
    36. Element is white and its edges coincide with other objects. E.g., GWB ceiling in RCP.
    Dave Jones's Avatar
    4,464
    11:31 AM
    LOL! yeah, that would be a tough one to overcome. I actually found another one yesterday. I got the list out because I had started a new project from an OOTB template and built a Rubik's cube shape out of ACM panels for testing 2 and 3 sided corner flexing. Views were good everywhere except nothing on level 2 or roof plans. Phase filter was set to Show All which obviously doesn't show all because I had to change it to None to see my panels in plan in those two views. So, there's a #35
    Dave Jones's Avatar
    4,464
    11:31 AM
    Quote Originally Posted by gdoherty0102 View Post
    View Range
    The light bulb
    Phases
    Worksets
    Design Options
    I agree that some of the items are semi dups or redundant but I wanted to post the list exactly as I had found it. I wish I remember where I got it from so I could give credit where credit is due.
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    07:31 PM
    Nr. 31 is actually off the record in 2011-versions.
    The object is part of an underlay obscured by another level (see this thread: http://www.revitforum.org/showthread...derlay-Ceiling)
    The object is set to be not visible by a visibility parameter (happened to me once)
    Austin, Texas
    283
    01:31 PM
    Thanks, Dave. #15 just helped me!
    Orlando, FL, USA
    2,955
    02:31 PM
    Quote Originally Posted by truevis View Post
    Good points... comments:
    # 35 : applies to walls only, so I don't know if it belongs to this list...
    # 35 : sounds valid.
    # 36 : isn't this already covered by one of the items on the list?
LinkBacks (?)
  1. January 3rd, 2012, 02:53 PM
  1. Plan view DBViewType has invalid view direction parameter.
    By Jj Mac in forum Architecture and General Revit Questions
    Last Post: March 22nd, 2011, 02:21 PM
Tags for this Thread
