Results 1 to 3 of 3
Like Tree2Likes
  • 2 Post By JCM
Thread: Curtain wall panel selection :)
    JCM
    JCM is offline
    December 17, 2010
    Pembroke Pines, FL
    571
    02:12 PM
    I just came across this and haven't seen it mentioned in too many places.
    It seems it makes a good tip for beginners
    If you select a panel in a curtain wall, and you want to avoid (tab/click selection for every panel in the same column or row of the panel you chose) then you can right click and select from the dropdown menu select panel > along vertical grid, horizontal grid, or on host
    THis will select the row of panel,
    the column of panels or
    all the panels in the system.
    Please let me know if any further clarification needed
    Hope this helps!
    Munkholm and elton williams like this.
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,234
    01:12 PM
    Never knew that. Sweet.
    Of course, I don't use curtain walls. But if I ever do...
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,523
    11:12 AM
    Quote Originally Posted by dzatto View Post
    well, when you get the 32 story lube shop with unitized rain screen curtain wall on four sides...call me
  1. Creating a new curtain panel
    By aaronlo11 in forum Architecture and General Revit Questions
    Last Post: October 1st, 2011, 11:35 AM
  2. Replies: 0
    Last Post: August 26th, 2011, 01:30 AM
  3. Revit OpEd: Curtain Wall Panel - Edit in Place
    Last Post: August 17th, 2011, 03:10 PM
  4. Curtain Wall Panel Tags
    By kipsmiks in forum Architecture and General Revit Questions
    Last Post: June 29th, 2011, 02:15 PM
