Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By tuekappel
Thread: atan entered as a fraction value i Revit
  1.    #1
    Member tuekappel's Avatar
    February 6, 2012
    Frederiksberg, Denmark
    334
    10:33 PM
    I don't know if this is common knowledge, but........-Did y'all know that you can enter an atan value as is in a slope parameter?
    Example:
    I need my roof to have a slope of 5%, or 1/20.
    The correct value in degrees is 2,86º, but i don't need to calculate it, i can just enter this formula:
    =1/20
    -and Revit will calculate the inverse tangens of that fraction!
    Works with decimal frations as well, in this case "=0.05" OR just plain =5%
    Really nifty, if you ask me.
    https://knowledge.autodesk.com/suppo...pe%20parameter
    Steve_Stafford likes this.
  2.    #2
    Coeur d Alene, ID
    4,779
    03:33 PM
    You can type in any formula that you want as long as you type in the = first. I created a fun little calculator (keys don't work...just type = and your equation when someone complained that Revit doesn't have a calculator.
    Attached Files Attached Files
  3.    #3
    February 6, 2012
    334
    10:33 PM
    Yeah, i try to teach this to all my colleagues, when i see them reach for their calculator.
    For this peticular example i was surprised that i didn't have to type "=atan(a/b)", since that's the correct formula in the family editor. Instead it's enough to just type "=a/b", and Revit assumes the atan, since the parameter type is slope.
    ordinary numbers are interpreted as angles, so "7" will be interpreted as 7º
  1. Calc Angle using atan.
    By doni49 in forum Architecture - Family Creation
    Last Post: July 2nd, 2013, 02:55 PM
  2. Detail callout displaying fraction
    By SuperScott in forum Architecture and General Revit Questions
    Last Post: May 9th, 2013, 03:46 PM
  3. How to set dmension for parts to Foot- inch fraction
    By billbe in forum Structure - Interoperability
    Last Post: May 28th, 2012, 09:24 AM
