Results 1 to 2 of 2
Thread: Units in the Properties Panel
    February 15, 2018
    1
    04:19 AM
    Hi
    I have a problem with the units in the Properties Panel. Every time I select a wall, door or whatever, in the properties panel units are in inches, and I want them in meters.
    I already set the general units of the project. Manage, Settings, Project Units
    Thanks
    Coeur d Alene, ID
    4,632
    11:19 PM
    Are you talking about the type names of the system families? Those don't change just because you change the units. You have to rename them and adjust the dimensions accordingly, or start with a metric project.
  1. Fixture Units Updates after updating units in families
    By edwardsdv in forum MEP - General
    Last Post: September 21st, 2017, 09:51 PM
  2. Replies: 0
    Last Post: September 11th, 2014, 11:45 PM
  3. Replies: 0
    Last Post: September 4th, 2014, 07:45 PM
  4. Replies: 0
    Last Post: August 26th, 2014, 03:45 PM
  5. Replies: 0
    Last Post: August 1st, 2014, 01:15 AM
