Results 1 to 2 of 2
Like Tree1Likes
  • 1 Post By willsud
Thread: how can i make and show the natural ground line on elevation
    May 21, 2013
    1
    10:02 AM
    Hi everybody,
    i am a newbie for revit software.
    Now i make the elevation like this picture. But i don't know how to make the Natural Ground line on elevation like that.
    Thank you for your help.
    Attached Thumbnails Attached Thumbnails how can i make and show the natural ground line on elevation-2017-10-12_152514.jpg
    December 13, 2010
    Ambleside, Lake District, UK
    743
    03:02 AM
    Welcome to the forum Gelink,
    I used to struggle with this in the early days - you really should model the landscape, even if just using floorslabs around the building which can be modified by using the 'modify sub elements' option to create slopes and triangulation, which then show a cut line in Elevation and Section Views, however when short of time I sometimes used a Masking Region to cover up the bits you don't wish to see in the elevation - either during or after creating the Masking Region you can edit the boundary so that only the top line is say, Wide Lines and the other lines are Invisible Lines, so they don't show.
    Editing the crop boundary of the View can also help but you cannot edit the View crop boundary lines like you can with a Masking Region.
    Hope that makes sense and is some help.
    cganiere likes this.
  1. Showing Natural Ground Slope in Section
    By brandsema in forum Architecture and General Revit Questions
    Last Post: April 19th, 2016, 11:08 PM
  2. Natural Ground Level
    By ashleye in forum Architecture and General Revit Questions
    Last Post: May 13th, 2015, 08:59 PM
  3. Show Model Line in Elevation and NOT 3D
    By DaveP in forum Architecture and General Revit Questions
    Last Post: April 15th, 2015, 09:33 PM
  4. symbolic line from elevation to make a profile family
    By jameshs in forum Architecture - Family Creation
    Last Post: October 18th, 2013, 01:14 PM
  5. How can i make the curtain system grid being straight line in elevation?
    Last Post: September 23rd, 2011, 09:17 PM
