Results 1 to 2 of 2
Thread: Stair by run length
    July 19, 2017
    4
    07:18 PM
    Stair by run length
    RevitLT 2016
    Is there a way to model a stair by specifying run length (by dimension or graphic input) and two established floor levels?
    For example: we have a fixed bottom landing edge and a fixed top landing edge (existing) and want to run a stair between the two with whatever tread length we need to span the fixed run length with the max riser specified.
    I get that it can all be done with math and calcs, just wondering if there is a setting in stair creation that would allow us to 'stretch' a stair to fit interactively and which outputs the right tread length for the fit.
    Thanks in advance.
    Michael
    Member lost again again's Avatar
    March 10, 2011
    Northern California
    360
    06:18 PM
    At the end of a stair run is a blue dot and a blue arrow. In the past, I always grabbed the wrong one of the two (the arrow) while trying to adjust the number of risers in a stair run, and I swear the other end of the run would stay put and the treads would become wider than defined by the stair family.
    Trying that same thing right now and dragging the arrow moves the whole stair, run which is no more helpful than just moving the stair run, so maybe 1) I've selected a bad type of stair to try this on, or 2) they've changed the reason for the arrow instead of just removing it from the program. I have a feeling my program is doing something goofy right now and won't allow the use of the arrow, but you might try it over there.
    Attached Thumbnails Attached Thumbnails Stair by run length-screen-shot-2017-10-25-2.59.15-pm.png
  1. How to model wall and stair skirting such that their length can be scheduled?
    By viratmanchanda in forum Architecture and General Revit Questions
    Last Post: October 19th, 2015, 05:55 PM
  2. stair path to show full length of stair REVIT 2015
    By ledgewood33 in forum Architecture and General Revit Questions
    Last Post: May 28th, 2015, 06:30 PM
  3. Limit Pipe length to practical standard length
    By amarkrish108 in forum MEP - General
    Last Post: January 8th, 2014, 02:27 AM
  4. Stair by Component - Stair tread profile & detail components
    By Jj Mac in forum Architecture and General Revit Questions
    Last Post: October 17th, 2013, 06:26 PM
  5. IFC - how to export length instead of cut length on framing
    By leetkinda in forum Structure - General Questions
    Last Post: August 17th, 2011, 05:38 PM
