Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Like Tree4Likes
Thread: Sheet Specs (in Revit) from Word
    March 21, 2013
    Phoenix, AZ
    275
    09:06 AM
    This procedure has been working smoothly for us, hope you can benefit from it as well.
    The basic workflow is Word -> PDF -> Image -> Revit (sheet). The idea is to do the editing / formatting in Word (or another robust editor), print your specs to "pages" that are the same size and width as a detail column of your title block (our detail boxes are 6" wide), and link those into Revit.
    Word has a page size limitation of 22"x22", so you will not be able to get a full column longer than 22". This may just barely work for 24x36 (depending on your borders), but it's too short for 30x42 or larger. The solution is to work at "75% scale" in Word and scale the print up to 100% in Revit. 75% of a 6" wide column is 4-1/2", so set your paper width for 4-1/2"; the length will vary by your sheet size (17-1/4" for 24x36; 21-1/2" for 30x42). Margins and text font will have to be scaled as well (I use 1/8" margins and 6pt font).
    Organize and format your specs; print to PDF (the 4-1/2" wide sheets). Convert PDF to images (if you have a way to get images directly out of Word, you may not need the PDF step).
    Insert the images onto a Revit sheet, scale them to be 6" wide, arrange on sheet.
    Images need to be re-imported if the text changes.
    October 4, 2016
    Spain
    50
    04:06 PM
    You can copy paste text from word to revit it is faster
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,479
    09:06 AM
    Quote Originally Posted by shyock View Post
    does the Word formatting come with the copy/paste? Don't have time to try it today so I ask innocently
    September 17, 2015
    4
    12:06 AM
    How did you do that? I'm trying to copy (Ctrl+C) a simple sentence from Word 2016 and paste (Ctrl+V) on Revit 2016 drafting view and it's not working
    September 17, 2015
    4
    12:06 AM
    Quote Originally Posted by sirky004 View Post
    I've figured it out.
    Quote Originally Posted by Dave Jones View Post
    short answer: nope
    just dumb texts
    October 4, 2016
    Spain
    50
    04:06 PM
    The format is not coming with the text.
    You need to create a text annotation first, when you're into it just paste the text copied
    May 3, 2012
    1,394
    05:06 PM
    I am also quite interested in how text could be linked to Revit.
    So far I think the most efficient way is to write your text in Excel (You could use .html .xml but excel is much more accessible than word), then read the text into parameters using Dynamo/Macro. So create a Detail Item with a multi-line text parameter to contain and display the text.
    Formatting is definitely an issue and there is a max limit 256 characters per text parameter, but this is the most 'BIM' solution with the least manual work once it is set up. If you standardise the excel sheets you can also get people who dont/wont do revit working in a more structured way with their data.
    Or do it the other way around. Just show links in revit (Links work in pdfs) that bring up text from a URL.
    March 21, 2013
    Phoenix, AZ
    275
    09:06 AM
    Quote Originally Posted by josephpeel View Post
    I do something similar (in Excel) for our sheet notes. From what I've found so far, you can only create a numbered list in a text note (on a sheet or view), not in a family. And you'll need to use the API to accomplish that (you can do Python thru Dynamo). And you're limited to the formatting you can use (you need to assign any paragraph formatting thru the API).
    The image workflow is great for specs because there is little need for continual manipulation of the spec data, especially in a situation where you're putting them on sheets in lieu of a Project Manual. Most spec libraries are in Word (or compatible). Third party specs will commonly arrive in Word or a Word-compatible format, so it is easier to integrate them (and match formatting) if your project specs are based in Word. And since you don't have to divide the text into columns (the print driver does that), you don't have to waste time dividing text into columns.
    josephpeel likes this.
    February 22, 2013
    316
    12:06 PM
    This is interesting. We've been writing our specs in AutoCAD Mtext and importing them into Revit. This works for us because of our legacy CAD standards and about 50% of our projects are still in CAD. But we are talking about re-building our drawing specs from scratch because they're such a pain to assemble. I'll give this method a try!
    EDIT: Okay, I've been playing around with Word for an hour and I must be missing something. I've set up the columns and scaled the font size down on the 22"x22" sheet, and also defined a custom Multilevel List that matches my Company's spec standard... but how in the heck do you control the indenting? There doesn't seem to be a way to make sure that automatically sets the indents so that it formats like I'm showing in the attached image. I can get the various levels to show up correctly (A. 1. a. etc. ), but how do you set the indenting for each level?
    Attached Thumbnails Attached Thumbnails Sheet Specs (in Revit) from Word-spec.jpg
    December 29, 2014
    Calgary, Canada
    178
    10:06 AM
    You can't set indenting for each level. It looks at the indent you specified in the text type and uses that (at least I'm pretty sure that's what it does).
  1. Minimum Cheap Laptop Specs for Revit
    By quixotic in forum Hardware and Infrastructure
    Last Post: October 16th, 2016, 08:58 PM
  2. Word Document in Revit?
    By Rich08 in forum Architecture and General Revit Questions
    Last Post: July 31st, 2014, 08:26 PM
  3. word (how to get it into revit)
    By Tom Dolle in forum Architecture and General Revit Questions
    Last Post: August 2nd, 2013, 03:19 PM
  4. Computer specs and Revit 2011
    By Gumpole in forum Hardware and Infrastructure
    Last Post: March 3rd, 2011, 12:14 PM
  5. Specs for Revit 2011
    By winn in forum Hardware and Infrastructure
    Last Post: January 12th, 2011, 07:11 PM
