Results 1 to 1 of 1
Thread: Align sweeps in 3D
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    12:19 PM
    Align sweeps in 3D
    It came up in this thread, so I thought I'd post a quick tutorial.
    It is possible to align the end of any kind of sweep in 3D to another building component.
    Building components can be real 3D objects such as walls, but also Surface Pattern lines or model lines. Only thing is that the alignment plane needs to be perpendicular to the path of the sweep.
    It's even possible to align the face of the sweep to the face of its host (something you would normally do with the "offset from wall parameter")
    I use this a lot since it's more secure then stretching the blue dot and try to place this in the correct place manually.
    See attached for more details.
    Attached Thumbnails Attached Thumbnails Align sweeps in 3D-ws3d_1.png   Align sweeps in 3D-ws3d_2.png   Align sweeps in 3D-ws3d_3.png   Align sweeps in 3D-ws3d_4.png   Align sweeps in 3D-ws3d_5.png
  1. Sweeps
    By ikinks in forum Architecture - Family Creation
    Last Post: July 22nd, 2011, 07:26 AM
  2. align command with floors (sub elements)
    By jbenoit44 in forum Tutorials, Tips & Tricks
    Last Post: June 15th, 2011, 02:23 PM
  3. align walls to be parallel
    By t1shep in forum Architecture and General Revit Questions
    Last Post: May 5th, 2011, 02:29 PM
  4. Align and lock an arc - door swing
    By Wiley in forum Architecture - Family Creation
    Last Post: February 26th, 2011, 09:58 PM
  5. Dimension to Sweeps
    By jdpeakplatinum in forum Architecture and General Revit Questions
    Last Post: January 4th, 2011, 08:51 PM
