Results 1 to 6 of 6
Thread: Creating a floor based and wall based generic model in a single family
    December 11, 2014
    6
    09:40 PM
    Hello everyone , I need some help for creating a generic model which works as both wall based and floor based in a single family when we load into project. can anyone please suggest me some idea to create such a family.
    Orlando, FL, USA
    3,107
    12:10 PM
    Start a family with the generic model template, then set "work-plane based" = yes, and "always vertical" = no.
    December 11, 2014
    6
    09:40 PM
    Hello Alfredo, I tried with the method you said but when I load it in the project which has a floor and wall , void is cutting only the floor but not wall. I took family template as 'generic model floor based'. Do you have any idea regarding the issue?
    St. Louis, MO
    1,954
    11:10 AM
    Try using GM Face-Based template.
    Perhaps "nest" the wall-face part into the floor-face family.
    Can you post an image of what you are trying to do, and/or the family?
    Orlando, FL, USA
    3,107
    12:10 PM
    Quote Originally Posted by PraveenPonnuru View Post
    Well, that's not what your original question said, was it? Did you mention that the family needed to have a void that was supposed to cut a wall and a floor at the same time? No, where did you say that?
    Sorry, but Revit uses one host at a time.
    Member doni49's Avatar
    February 26, 2013
    Jefferson City, MO
    441
    11:10 AM
    Alfredo,
    Based on my reading of the OP's second message, I think maybe he was saying that he was able to get it to cut the floor but not the wall (I don't necessarily think they're both supposed to be cut at the same time).
    I also see that he said he used a "Generic Model Floor Based" template. That would account for not being able to cut the wall.
    As Cliff suggested, use Generic Model Face Based and follow Alfredo's instructions.
    Creating a floor based and wall based generic model in a single family-revitgenericmodelfacedbased.png
    EDIT: After posting this, I tried to make an example file. For some reason it doesn't want to cut the Floor OR the Wall in my tests. (yes it is set to Cut on loading). Once I get it resolved, I'll post it.
  1. Generic Model Floor Based Floor
    Last Post: June 6th, 2014, 04:19 PM
  2. How do I control the elevation of a generic model wall based?
    By joekingturtle in forum Architecture - Family Creation
    Last Post: July 23rd, 2013, 10:41 PM
  3. Generic model floor based line weights
    By redmonki in forum Architecture - Family Creation
    Last Post: June 18th, 2013, 03:51 AM
  4. Make Generic Model Adaptive > Floor Based
    By qutaibah in forum Architecture - Family Creation
    Last Post: November 1st, 2011, 07:20 AM
  5. Generic model wall based
    By bangobeat in forum Architecture - Family Creation
    Last Post: July 29th, 2011, 06:25 PM
