Results 1 to 9 of 9
Thread: equality coolness
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    11:46 AM
    equality coolness
    Maybe this is well known, but I just stumbled across this:
    Let's say you have a few walls which need to be dimensioned on equal distances Face to Face. This would be the workflow for me:
    1. Dimension Core to Core and put equality constraint
    2. Delete the dimension but keep the constraint. (a major reason to work with Work- and Plotviews btw)
    3. Redimension on Wall Face.
    This kind of gets complicated when walls have different thicknesses. Then you need to due the math manually and lock the dimensions.
    Today I stumbled across an alternative which is going to save me a LOT of time!
    1. Dimension Core to Core and put in EC.
    2. Select the dimension line and choose Edit Witness Line
    3. Set the Witness Lines to the Wall Faces
    4. To my great surprise, the EQ returned! You now have an equality constraint on the distance between the wall faces. And a surprisingly redundant one. I stretched, changed Wall thickness and all. But I wasn't able to break the constraint.
    I put some printscreens with this post. Hope it helps you as it will me.
    Attached Thumbnails Attached Thumbnails equality coolness-equal6.png   equality coolness-equal5.png   equality coolness-equal4.png   equality coolness-equal3.png   equality coolness-equal2.png
    Moderator mark b's Avatar
    NSW Australia
    1,429
    10:46 PM
    Didn't know that one! Nice, I like..........
    Kingdom of Denmark
    4,204
    12:46 PM
    Bizarre.... but very cool! POTM nomination for sure
    Alex Cunningham's Avatar
    December 8, 2010
    Northern California
    3,567
    04:46 AM
    Martijn... try deleting your dimension and see if you get a box that asks you to keep constraints or not... something like this.
    Member ikinks's Avatar
    March 10, 2011
    the Netherlands
    163
    12:46 PM
    I can replicate this with 3 walls, but trying the same workflow with 4 breaks the constraint.
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    11:46 AM
    Quote Originally Posted by Alex Cunningham View Post
    Yeah, it does. But that wasn't the point. The point was that you can put an equality constrain on the interior measurement of a set off walls, instead of only constrain wall centerlines (which, with walls from different width does NOT give the right constraint for internal measurement).
    ikinks:
    No it doesn't. But it does need a slightly different approach:
    In order for this to work on more then 3 walls. You need to manually replace the witness line from center to a wall face (using the grips) and then use edit witness lines to dimension the second wall face. It will work then.
    mno
    mno is offline
    Junior Member mno's Avatar
    April 12, 2011
    Amsterdam, the Netherlands
    30
    01:46 PM
    Looks interresting, but I can't get it to work.
    Ofcourse I want this to work with any number of walls.
    (3 or 4 seperation walls between 2 concrete walls for example)
    This is what I do:
    - create 4 walls between 2 walls
    - dimension all walls core-to-core
    - set to EQ
    - If I edit the witness lines of the 4 inner walls I create the dimension of the wall-thickness
    - I move the outer lines using grips to the innerface of the 2 outside walls
    - the dimension from both outside walls to the closest seperation wall are both equal
    - the dimension between the 4 inner walls are equal but different...
    - If I now click on EQ, the left 5 walls are equal, but the right one is not...
    I'm probably missing something here, but what?
    Now that I know this is possible I want to use it!!
    Attached Thumbnails Attached Thumbnails equality coolness-eq-coolness-image-2.jpg   equality coolness-eq-coolness-image-1.jpg
    Last edited by Alfredo Medina; September 9th, 2011 at 02:09 PM. Reason: Replaced in-line attachments with regular attachments...
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    11:46 AM
    Can't see the inline attachment but I can reproduce this... Have to look into it more. I'll do so, right after I finished my Curtain Wall excersize. I believe it has something to do with the placement of the "equality anchor" but not quite sure. I'll get back to you on this.
    August 16, 2011
    9
    07:46 AM
    As a followup here, I am wondering if anyone has a shortcut to center a group of elements (light fixtures, in this case) in a room, where the unit spacing is different in the middle than on the outsides? So, for example, there are two fixtures, 6 feet apart, and the distance to the walls is EQ but unknown (as in, anything not 6' (and thus not EQ across the entire dim string).
    I think this would be easy if I knew how to create a discontinuous but related set of dimensions. I'm not sure that would even exists...
    Suggestions would be really appreciated.
    Ed: My apologies, it turns out this IS as easy as it is... Presumably I have a setting checked somewhere b/c the two of us sitting here are doing the exact same process and yet hers works and mine doesn't.
  1. Mobile forum coolness
    By Gordon Price in forum Forum Suggestions and Feedback
    Last Post: April 29th, 2011, 03:38 AM
