Results 1 to 5 of 5
Like Tree2Likes
  • 2 Post By mark b
Thread: Picket Fence by Beam System
    Moderator mark b's Avatar
    NSW Australia
    1,427
    11:34 AM
    Here is an old trick I had forgotten about and just got me out of trouble again, using Structural Beam systems for picket fencing.
    Just make your picket in a Structural Framing - Beams and Braces family template, then use this as your beam in a Structural Beam System. (Structure tab/Beam System).
    Draw yourself a referance plane (named) where you want your fence then set your work plane as this named ref.plane. draw any shape you like, even splines. If you pickets end up upside down pick the opposite side as Beam Direction.
    Attached Thumbnails Attached Thumbnails Picket Fence by Beam System-fencing.jpg   Picket Fence by Beam System-fence-2.jpg
    Attached Files Attached Files
    ghost3203 and sharas like this.
    Autodesk Kevin Dolley's Avatar
    April 18, 2011
    Boston
    11
    08:34 PM
    That's pretty clever.
    Orlando, FL, USA
    3,000
    07:34 PM
    Excellent, Mark! Thanks for sharing!
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    12:34 AM
    Nice tip! Rep for you...
    JTB
    JTB is offline
    Member JTB's Avatar
    December 30, 2010
    Athens, Greece
    124
    02:34 AM
    Quote Originally Posted by mdradvies View Post
    +1
  1. Beam system behavior using trusses?
    By edwinguerra in forum Structure - General Questions
    Last Post: June 21st, 2011, 12:01 AM
  2. Beam Poking Through Roof Help
    Last Post: May 6th, 2011, 10:44 AM
  3. Variable beam creation
    By lucis29 in forum Architecture and General Revit Questions
    Last Post: April 8th, 2011, 01:53 PM
  4. Beam system:noob question
    By jbenoit44 in forum Structure - General Questions
    Last Post: March 27th, 2011, 11:37 PM
  5. Beam and void
    Last Post: March 19th, 2011, 03:58 PM
