Page 42 of 43 FirstFirst ... 32383940414243 LastLast
Results 411 to 420 of 426
Like Tree207Likes
Thread: Revit Formulas for "everyday" usage
  1. #411
    May 7, 2018
    Ballum, Ameland
    4
    01:08 PM
    If I know C and and S, can I get R?
    Quote Originally Posted by Munkholm View Post
    Ever needed to calculate circular segments? Made this one earlier, to get the radial arrays right in this family, but figured that it might come in handy for something else, so saved it out at a early stage.
    PS: this if from the circular segment formula.
  2. #412
    Kingdom of Denmark
    4,221
    02:08 PM
    I believe that it should be possible, but surely would be easier to get R if you also know h
    Link to the article I used back then: https://en.wikipedia.org/wiki/Circular_segment
  3. #413
    May 7, 2018
    Ballum, Ameland
    4
    01:08 PM
    Yes, I also expect it to be possible... Been wrestling with it for a few day now though :-)
  4. #414
    May 7, 2018
    Ballum, Ameland
    4
    01:08 PM
    From that wiki:
    One can reconstruct the full dimensions of a complete circular object from fragments by measuring the arc length and the chord length of the fragment.
    So, it should be possible... no luck so far though :-(
  5. #415
    Kingdom of Denmark
    4,221
    02:08 PM
    Found an article which suggest that it's only possible to do an approximation with Newton's method (Sometimes called the Newton-Raphson method)
    I'm usually pretty good at this stuff, but this one have me puzzled, and I'm starting to think that it's not possible after all. But please do let me know if you figure it out.
    Given the arc length and chord length, what is the radius? - Math Central
  6. #416
    May 7, 2018
    Ballum, Ameland
    4
    01:08 PM
    yes, I found those too. I believe you are correct, if smarter guys as us can't find a solution, we should probably just give up
    I will be looking at the approximation, maybe combined in a lookup table to come to a solution for the family.
  7. #417
    Orlando, FL, USA
    3,093
    08:08 AM
    Hello, I don't know if this had been posted before, but I could not find it anywhere here, so I am going to add this info to this thread in case it's useful for someone in the future: how to find the cube root of a value in Revit.
    You know that for square roots we have a function, so we simply type sqrt (x) to find the square root. For example, if x = 16, then sqrt (x) is 4.
    But how do we get the cubic root of a value? I thought there was a function for it, such as crt (x) or cubicroot (x), or croot (x) but no, none of those functions exist in Revit.
    So the syntax for cubic root is this: x ^ (1/ 3)
    For example, you have a parameter x whose value is 129, and you need a number that x * x * x is 129, then you create a new parameter, say "y" and make it equal to x ^ (1/ 3) . The result is 5.052774 , that's the number that multiplied three times by itself gives 129 or actually 128.999...
    In the same way, finding the n root of a value x in Revit is: x ^ (1/n)
    Why was I needing a cube root? Because I needed to find the radius of a hemisphere given its volume, and I read that the formula requires a cuberoot and I didn't know how to do a cuberoot in Revit.
    Attached Thumbnails Attached Thumbnails Revit Formulas for "everyday" usage-2018-12-10_9-04-42.jpg
  8. #418
    January 24, 2016
    Florida
    1
    08:08 AM
    Help for Circle Segment Calculations
    Quote Originally Posted by Jaapf View Post
    As others have noted, Revit cannot do calculate the radius from only the chord and arc length since it does require Newton's Method.
    See http://mathforum.org/dr.math/faq/faq.circle.segment.html for an excellent, complete, easily used source for calculating any part of a circular hemisphere based on just two parameters. There is a link provided on the site to an Excel file created by Dan Erb with well presented and organized calculations including solving those cases which require Newton's Method. For convenience I am including it here http://mathforum.org/dr.math/gifs/ChordMath.xls. However, together The Math Forum and Dan Erb's spreadsheet provide a very comprehensive understanding and convenience in solving these kinds of problems.
  9. #419
    pgk
    pgk is offline
    January 4, 2019
    1
    06:08 AM
    Hello!
    So I've been using Revit on and off for about 3 years now and I'm currently trying to write my first formula. I think I have the "concept" of what I want it to do correct, but Revit keeps scolding me for "Improper Use of Boolean Expressions" and despite all my meddling and reading I can't figure out why.
    if(Invert Elevation < 15', Invert Elevation, (Invert Elevation-15'))
    That's the formula I have as currently written. What I'm trying to achieve is this:
    I have an hvac model with piping. I need to be able to call out the invert elevation of the piping in a tag. The tag I have works great on the first floor of the building, but when I go up to the second floor it still reports the value in relation to "elevation 100", which is 15 feet below the second floor level.
    So I created a new parameter in the tag called "Invert Elevation 2nd floor only", to go along with the "Invert Elevation" parameter that's currently in said tag.
    I thought if I could get the formula to check to see if the initial Invert Elevation is less than 15 feet I'd have it still report the normal "Invert Elevation" value, but if that parameter read a value *larger* than 15 feet it would take said value and subtract 15 feet from it, then report that final value (giving me an invert elevation based off the second floor plan level instead of the first.)
    I hope I explained it clearly enough. If anyone has any input for a formula newbie it'd be much appreciated!
    Thanks!
  10. #420
    October 14, 2011
    Boston, MA
    220
    07:08 AM
    one thing that could be added is a Simple OR Statement for yes/no parameters
    OR (A=True, B=True)
    if either A or B is true, then the result is true
    despite how easy it turned out to be it's not always immediately apparent how to make a yes/no <true> or <false>
    I fell into the trap of trying to do IF ( OR (A=True, B=True) <True>, <False> ) ).....
LinkBacks (?)
  1. February 28th, 2012, 03:07 PM
  2. January 10th, 2012, 01:31 PM
  3. January 2nd, 2012, 06:57 PM
  4. December 2nd, 2011, 11:31 AM
  5. November 4th, 2011, 09:59 AM
  1. Fórmulas de Revit para el "uso diario"
    By Munkholm in forum Foro Español
    Last Post: December 14th, 2017, 05:44 PM
  2. Replies: 3
    Last Post: March 18th, 2016, 10:32 PM
  3. Slab slope discrepancy btw "Slope arrow" and "Define Slope"
    By jh75 in forum Structure - General Questions
    Last Post: May 6th, 2011, 08:39 PM
  4. Revit 2011 - "Black rendering" with Non-English Win XP
    By Munkholm in forum Tutorials, Tips & Tricks
    Last Post: January 10th, 2011, 08:15 AM
  5. Replies: 2
    Last Post: January 7th, 2011, 06:19 PM
