Page 24 of 24 FirstFirst ... 142021222324
Results 231 to 238 of 238
Like Tree118Likes
Thread: Building a Revit Template
  1. #231
    December 21, 2010
    Phoenix, AZ
    2,429
    08:50 PM
    Quote Originally Posted by kunster View Post
    taking into account scales
    I'd rethink this. Most people I've seen do this are trying to change lineweights by scale but Revit already has a built-in process to manage that. If you're controlling visibility of geometry by scale, sure, but not otherwise.
  2. #232
    Mr. Revit OpEd
    2,736
    07:50 PM
    Don't forget that VT's don't have to act on every available feature in the list. Un-checking the box on the far right means ignore these settings please. Put another way, Un-checking the Scale setting means one template can be applied to a variety of plan views at different scales and the only thing that doesn't have to be the same is the scale.
  3. #233
    December 21, 2010
    Phoenix, AZ
    2,429
    08:50 PM
    Right. Thanks for clarifying how to not just to do!
  4.    #234
    April 30, 2015
    Michigan
    135
    10:50 PM
    I'm note sure about placing shedules on sheets. The thing that is giving me pause is the large amount of variability in size that schedules can have from project to project. Some equiupment schedules like VAV in particular can range from single digits to a hundred or more. How could you possible put that on a sheet without just adding work to move it around later?
  5.    #235
    December 21, 2010
    Phoenix, AZ
    2,429
    08:50 PM
    It's not really adding work since you would have to place it before you could move it around later.
  6.    #236
    9,673
    09:50 PM
    Quote Originally Posted by CRapai View Post
    So if you dont place it on a sheet at all, you guarantee 100% of the project have to do something, to finish the job.
    If you place it on a sheet, and guess at the size of the schedule based on a typical job, even if you only get it right for 40% of the jobs.... Now 40% of your teams dont have to do it? And 60% just have to move/adjust it?
    I dont get your logic at all. I have tons of schedules all on sheets, and they all work without adjustment in all but the most extreme projects. But hey, if it makes you happier, leave them off the sheets!
  7.    #237
    January 17, 2019
    3
    03:50 AM
    Thanks for your feedback on naming objects. I'm coming back to the topic of view templates and project browser organisation, which I find a very difficult one to sort out. It's doing my head in to find a simple and clean way of organizing it.
    In our office project files usually contain several project phases, especially building permission plans which are worthwhile to keep just until the end of the project. Now, would you create a view Template for each phase, scale and type of plan/ section, etc. or would you try to minimize the number of VT's so to say one at each scale, yet multi-phase for exemple ? in the first case I would end up with around 300 VTs,
    Tutuapp 9apps Showbox in the second maybe 30.
    Thanks for your comments
    30 for the second I think it's not me I would end up with about 500 VT in the second 60
    what do you think?
  8.    #238
    9,673
    09:50 PM
    Quote Originally Posted by klimbo123 View Post
    what do you think?
    I wouldn't use either slice of logic that you quoted in that post, honestly.
    Different VT's by Phase is pointless, because the phase parameter doesn't need to be in the View Template. In fact, I don't even think it can be.
    View types show different things. Sometimes the view types are the same scale. Sometimes they are different scales. I make view templates for different view types, end of story. Vertical circ plan vs enlarged plan. Both may be 1/4 inch but may show different things.
    It's not incredulous, and you still shouldn't end up with more than 50. I have almost 3000 sheets with views in my template. Doesn't need 50 VT's.
    Aaron Maller
    Director
    Parallax Team, Inc.
  1. Consultant Links in the template: Best Practices
    Last Post: October 22nd, 2018, 05:42 PM
  2. Revitforum Template - Doors
    By mdradvies in forum Nederlands forum
    Last Post: August 30th, 2011, 08:43 AM
  3. View Template Best Practice
    Last Post: May 21st, 2011, 11:18 AM
  4. Update template to RST2012 problems
    By jh75 in forum Structure - General Questions
    Last Post: May 17th, 2011, 03:40 AM
  5. What is the Window-Curtain Wall template used for?
    By t1shep in forum Architecture - Family Creation
    Last Post: May 3rd, 2011, 10:05 PM
