Page 23 of 25 FirstFirst ... 1319202122232425 LastLast
Results 221 to 230 of 242
Like Tree122Likes
Thread: Building a Revit Template
  1. #221
    December 21, 2010
    Phoenix, AZ
    2,556
    01:31 PM
    No freaking way i would put families in folders based on category. Life sucks when you have to find something, like that.
    I'll bite... how do you organize them outside of Revit? By CSI? Assembly code/Uniformat? Lumped into the same folder?
  2. #222
    January 19, 2012
    322
    03:31 PM
    Since I use CTC's (ATG) BIM List I'm inclined to just keep the Categories as CSI #'s & then Revit Categories would add lots more top level folders for me. I typically have 2 Levels when there is lots, but in rare occasions where I have tons of content for Site/Specialty Equip & where I use nested content it goes to 3rd level. I see the advantages of maintaining primarily top level folders & then a 2nd level for nested content maybe.
    Until my schedule allows it I really would like to look into implementing a "CSI#-Revit Category-Subcategory" named Top Level only Folder Structure (with exceptions for nested content possibly). Less mouse clicks/navigating for sure.
  3. #223
    10,038
    03:31 PM
    Mine are by Master Format. Single Level of folders only. Flat hierarchy. There are just a lot of folders, which is fine.
    Sub folders make hunting for stuff suck.
  4. #224
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,108
    04:31 PM
    How do you handle the bits and pieces that are needed for families but don't specifically end up in projects as a line-item? Stuff like Casters, Window Sashes, Buttons & Switches, etc.
  5. #225
    10,038
    03:31 PM
    Good point. I should clarify, all of the Parent Level Folders DO have one subfolder that is called "parts" which is where UNSHARED nested families (such as casters, buttons, etc) go. If they are Shared Families, they are in their own folder somewhere.
    GMcDowellJr and cellophane like this.
  6. #226
    May 12, 2012
    paris
    91
    09:31 PM
    Thanks for your feedback on naming objects. I'm coming back to the topic of view templates and project browser organisation, which I find a very difficult one to sort out. It's doing my head in to find a simple and clean way of organizing it.
    In our office project files usually contain several project phases, especially building permission plans which are worthwhile to keep just until the end of the project. Now, would you create a view Template for each phase, scale and type of plan/ section, etc. or would you try to minimize the number of VT's so to say one at each scale, yet multi-phase for exemple ? in the first case I would end up with around 300 VTs, in the second maybe 30.
    Thanks for your comments
  7. #227
    10,038
    03:31 PM
    I have different view templates for Design and Documentation (because the drawings fundamentally look different), and different ones for each type of View in my set of drawings. Aside from Design and Documentation being different things, there is no point to multiple view templates for different PHASES, assuming you mean two different documentation phases of work.
    No idea how you would end up with 300, either. Thats insane.
  8. #228
    December 21, 2010
    Phoenix, AZ
    2,556
    01:31 PM
    Per scale would get you there... or close. Why, I have no idea, but sure.
  9. #229
    May 12, 2012
    paris
    91
    09:31 PM
    thanks, not linking the VTs to a project phase makes sense, yet only for plans i end up already with 20 taking into account scales and building phases like existing, demolition and project
  10. #230
    10,038
    03:31 PM
    Okay, well... 20 is nowhere near 300. And there are way more Plan types than everything else, at least in my Template. So i cant see how youll get anywhere near 300. I have 71 total, at the moment.
  1. Consultant Links in the template: Best Practices
    Last Post: October 22nd, 2018, 05:42 PM
  2. Revitforum Template - Doors
    By mdradvies in forum Nederlands forum
    Last Post: August 30th, 2011, 08:43 AM
  3. View Template Best Practice
    Last Post: May 21st, 2011, 11:18 AM
  4. Update template to RST2012 problems
    By jh75 in forum Structure - General Questions
    Last Post: May 17th, 2011, 03:40 AM
  5. What is the Window-Curtain Wall template used for?
    By t1shep in forum Architecture - Family Creation
    Last Post: May 3rd, 2011, 10:05 PM
