Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Like Tree10Likes
Thread: Find and Replace Materials for Revit
  1. #21
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,124
    02:52 AM
    Is the window not resizable or am I missing something? I've got old 24" monitors and the window is bigger than my screen
  2. #22
    Junior Member PolynineStudio's Avatar
    April 25, 2017
    31
    01:52 AM
    @cellophane
    The window is fixed unfortunately. We will unlock the scaling in the next update. Sorry for the inconvenience.
  3. #23
    August 9, 2011
    Louisville, KY
    6,124
    02:52 AM
    No problem - thanks for the update
  4. #24
    Member rbcameron1's Avatar
    August 15, 2012
    USA
    191
    12:52 AM
    This looks very interesting. I'm going to share this with an architecture tech consultancy that needs to see this. very cool.
    Couldn't you just have a Revit file with all your templated materials already loaded that you continue to build on? Than just transfer them into each model you want? That's basically what I do now. Purge out all the junk, then quickly load my materials that I always use on projects.
    cganiere likes this.
  5. #25
    April 25, 2017
    31
    01:52 AM
    Thank you for your interest and sharing the app.
    Yes: Ideally, you would start with a template and you will have all your materials organized. However, material updates to that template could deprecate the material standards in older projects, and sometimes those elements find their way into new projects. With the app you can quickly detect these errors.
    The app also allows for unique workflows that would be otherwise time consuming:
    • helps with the process of creating template material standards by merging and replacing materials in all elements; at this point you would be dealing with multiple materials that are not consolidated / follow a standard.
    • quickly update Revit project received from a 3rd party to your firm's material standard
    • for rendering, the appearance assets can be quickly consolidated via keyword search
    Side note / Quick Update: We are currently looking at adding support for digging into the families of a project and accessing the materials that are not available in the project environment. In this process, the app would be fully functional in the family editor environment. Right now the family editor environment is limited to materials that are not assigned to parameters. (Materials assigned to parameters are accessed via the project environment)
    You can somewhat mass process families in the project environment already by using the Juan Osborne Tools: MassLoad Families & MassSaveFamilies (under the TransferSingle plugin) in junction with our plugin.
    • Mass load families in a project file.
    • Load company standard materials.
    • Replace the materials assigned to parameters within those families with correct materials.
    • Then mass save the families. They should save with the new materials that you assigned in the project environment.
  6. #26
    April 25, 2017
    31
    01:52 AM
    Sneak peek of new features in upcoming release
    Nested Families Family Environment
    Remove Assigned Materials
    User Interface
    Attached Thumbnails Attached Thumbnails Find and Replace Materials for Revit-05modes.gif   Find and Replace Materials for Revit-03removec.gif   Find and Replace Materials for Revit-04nestedfamiliesc.gif
  7. #27
    April 25, 2017
    31
    01:52 AM
    Version v1.4.0 Released
    We have released v1.4.0 for the Find and Replace Materials Addin
    To download the latest: https://apps.autodesk.com/RVT/en/Det...ng=en&os=Win64
    Version v1.4.0
    • FEATURE: Run in Family Editor environment with nested family support.
    • FEATURE: Materials can be removed from elements and family documents by selecting the "<By Category>" option as new material
    • FEATURE: Option to delete previous materials from Revit document after replacing (accessed under settings menu)
    • FEATURE: Spacebar inverts the checkbox of selected items | Ctr-A selects all | Click-drag selects multiple
    • Revit 2019 support.
    • Improved graphic user interface and graphic performance.
    • Automated licensing process & subscription licensing
    • Introduced new monthly subscription tier.
    • Added Settings Menu.
    Feature Road Map
    • Eyedropper tool for quick/graphic material selection from model view (similar to SketchUp).
    • Paint bucket tool for quick/graphic material replacement from model view (similar to SketchUp).
    • Replacing materials using the transfer project standards API.
      • Option to switch between engine modes.
      • This mode will bypass all element specific API limitations, but will sacrifice the ability to control and preview which elements are affected.
    • Non-modal mode
      • Option to keep plugin open for multiple iterations.
      • Running the plugin will not pause the Revit application.
    • Batch process Revit Projects and Revit Families
    • Show/orient to affected elements selected.
    • Add rails structure support. Contingent on Autodesk's release for Revit API access to this element.
    • Fully support integrated wall sweeps. Contingent on Autodesk's Revit API update to error correct the behavioral anomaly for this element.
    We would really appreciate feedback on the feature road map. Thank you again for the continued support and interest!
    avorwerk likes this.
  1. Finding elements find/replace tool
    By katewood1989 in forum Architecture and General Revit Questions
    Last Post: September 21st, 2016, 10:22 PM
  2. Replies: 7
    Last Post: June 24th, 2016, 05:38 PM
  3. Can't find materials Notification
    By Tim West in forum Coordination Tools
    Last Post: March 21st, 2016, 07:21 PM
  4. Find and replace
    By andyhoman1 in forum Architecture and General Revit Questions
    Last Post: May 9th, 2012, 06:04 PM
  5. Autodesk Find and Replace
    Last Post: July 12th, 2011, 03:45 PM
