Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 27
Like Tree10Likes
Thread: Find and Replace Materials for Revit
  1. #11
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,124
    06:58 AM
    Quote Originally Posted by cpercer View Post
    Basically what I'm after is a material library manager that makes it as easy to merge/replace/delete materials as easily as the app does. I realize that currently the app does not do that, but being as it's V1 and Polynine is asking for feedback, I figured I'd ask.
    As far as I know the materials API is still pretty locked down, even going through Dynamo and what you are asking might not even be available.
  2. #12
    Junior Member PolynineStudio's Avatar
    April 25, 2017
    31
    05:58 AM
    @cpercer Thank you for your valuable feedback. I think what your asking for is a great idea. You can already do this by manually clicking on the bottom line in the batch rules, and type in directly what material assignments you desire. If the material is not detected in the current project then it will be grayed out. If the rule already exists, or you are assinging the same old material to two new materials, one of the rules will be highlighted in blue letting you know that the rule is redundant. (This behavior can also be prompted if the old material and the new material is the exact material, a rule that can only be registered by manually typing it in). When using the add rule button, these redundancies are automatically addressed. Let me know if this makes sense. A mini tutorial could also help showcasing the feature mentioned above.
  3. #13
    April 25, 2017
    31
    05:58 AM
    Regarding the deletion of materials, a feature for deleting materials after replacing or simply deleting a material can be easily implemented. This feature was omitted because there are some areas that the api does not allow access to the material attributes, and for those unique scenarios it's a safer approach to leave the feature out.
    The current strategy for removing unused materials would be via the built in Revit purge.
    However, we can look further into how this could be implemented.
  4. #14
    August 9, 2011
    Louisville, KY
    6,124
    06:58 AM
    Polynine - are you able to access material assets in addition to the top level material to perform similar actions?
  5. #15
    April 25, 2017
    31
    05:58 AM
    @cellophane For the initial scope of the app, material assets were not a point of focus, as the material element itself is the changing variable.
    From our preliminary research, re-assigning existing material assets is straightforward.
    Creating material assets from scratch is very limited.
  6. #16
    August 9, 2011
    Louisville, KY
    6,124
    06:58 AM
    Quote Originally Posted by PolynineStudio View Post
    If it isn't a huge ordeal programmatically I'd love to be able to analyze & cleanup material assets at the same time but it isn't the end of the world if you can't do it easily. While my materials are at least kind of in-shape I haven't made to assets yet and I know it is i mess.
  7. #17
    April 25, 2017
    31
    05:58 AM
    @cellophane I'm sure that other users are finding themselves in a similar situation regarding material assets.
    We will explore the feasibility of implementing the feature and possibly release an update.
  8. #18
    April 25, 2017
    31
    05:58 AM
    We have an update to announce: the Find and Replace Materials for Revit plugin trial has been extended from 15 days to 30 days. To download the latest install that includes this update, please follow the link below:
    https://apps.autodesk.com/RVT/en/Det...ng=en&os=Win64
  9. #19
    April 25, 2017
    31
    05:58 AM
    Sneak peek: Find and Replace Materials Plugin for Revit - Material Assets
    Attached Thumbnails Attached Thumbnails Find and Replace Materials for Revit-frm-assetpreview.gif
    cellophane and cganiere like this.
  10. #20
    April 25, 2017
    31
    05:58 AM
    Thanks to cpercer and cellophane for the feedback / feature requests. These requests are now included in our updated app now available for download:
    https://apps.autodesk.com/RVT/en/Det...21081710349606
    Here are the updates:
    - FEATURE: Find and replace material assets (Appearance, Physical and Thermal) in standard and batch processing modes.
    - FEATURE: Show Unassigned Materials toggle for the materials to replace list.
    - Updated the Single License system to allow for transferring licenses.
    - Introduced an alternate licensing solution for volume purchases: Enterprise Licenses.
    cellophane likes this.
  1. Finding elements find/replace tool
    By katewood1989 in forum Architecture and General Revit Questions
    Last Post: September 21st, 2016, 10:22 PM
  2. Replies: 7
    Last Post: June 24th, 2016, 05:38 PM
  3. Can't find materials Notification
    By Tim West in forum Coordination Tools
    Last Post: March 21st, 2016, 07:21 PM
  4. Find and replace
    By andyhoman1 in forum Architecture and General Revit Questions
    Last Post: May 9th, 2012, 06:04 PM
  5. Autodesk Find and Replace
    Last Post: July 12th, 2011, 03:45 PM
