Hello everyone,
The new Revit export add-in for Twinmotion 2016 is available online. The release number is
V2.0.6.0
You can find them at the link: Downloads - twinmotion or in Autodesk app store.
In order to use them, please first uninstall the previous release. After that you can run the .msi
If the release number on the plugin interface in Revit is different from 2.0.6.0 you may have to uninstall manualy the old version. Go to C:\ProgramData\Autodesk\Revit\Addins\2014, 2015 or 2016 depending on your Revit release and suppress the twinmotion .addin. You can then relaunch the .msi installation.
Any question about the add-in or about Twinmotion are welcomed, I'm here for you
Tianxiao
KA-RA / Twinmotion
www.twinmotion.com
