Results 1 to 3 of 3
Thread: Case Design Inc Addins - Delete All Views, Sheets and Links.
    Member ThatBIMGuy's Avatar
    May 23, 2011
    Denver, CO
    461
    10:28 PM
    Does anyone use this? I've been using it religiously in my office and its worked flawlessly. We've recently acquired another firm and in our initial get together about standards, I brought this addin to their attention. They have since installed it. Yesterday I got an email from their Revit guy asking if I had any issues with it. It would delete the sheets and said it deleted the views, but no views (or at least it appeared as though) were deleted. He ran it several times and got the same result. I told him I just used it last week and it worked fine for me. Well, I tried it later that morning and sure enough, it was doing the same thing for, not working. I thought maybe it was because I have 2014 now installed on my machine, but that wasn't the case because I tested it on several other machines in the office to get the same results. It would get about an inch on the progress bar and stop the first time and then get about 1/2 inch from the end of the progress bar subsequently and stop as well. The only other thing I can it could be, would be an update to Windows.
    Ive contacted the developer, but haven't heard anything yet.
    Is anyone else having this issue?
    Thanks
    Member MrBIMtastic's Avatar
    August 2, 2012
    Phoenix, AZ
    151
    09:28 PM
    Quote Originally Posted by BCERBIMMan View Post
    Thanks
    I used it yesterday, but before I was able to use any of the tools, I had to update/install them with the Addin Manager. See if that fixes the problem.
    They are usually pretty quick to respond. Have you heard anything?
    May 23, 2011
    Denver, CO
    461
    10:28 PM
    Quote Originally Posted by MrBIMtastic View Post
    I did, but have been busy at work. One of the senior developers emailed me back. he had to do several updates over the last few days. Its "working" now after the latest update from today but its not quite as quick as it was in previous working versions.
  1. Rotate plan views – not the views on the sheets
    By jh75 in forum Architecture and General Revit Questions
    Last Post: May 30th, 2013, 09:36 AM
  2. Revit OpEd: Case App Delete Sheets Views and Links
    Last Post: May 20th, 2013, 03:15 PM
  3. Replies: 0
    Last Post: March 9th, 2013, 10:15 AM
  4. Replies: 0
    Last Post: June 13th, 2012, 05:15 AM
  5. Revolution Design - Productivity Addins for Revit
    By Steve Faust in forum Commercial & Free Add-Ins/Extensions
    Last Post: November 30th, 2011, 05:51 AM
