Results 1 to 5 of 5
Thread: Colors of IFC
    Member HansLammerts's Avatar
    April 22, 2011
    441
    07:02 PM
    Colors of IFC
    Is there any other method to color the color of the output, other than material?
    I'm looking for a simple tool or way to force rebar diameters into colors.
    Thanks
    July 10, 2018
    India
    3
    12:32 AM
    You can edit dimension in type properties and make changes as you want.
    I am Sure you got all dimensions in color as you assign. also check settings of IFC in Application.
    Find Image for more details.
    Attached Thumbnails Attached Thumbnails Colors of IFC-ifc-export-options.png
    April 22, 2011
    441
    07:02 PM
    Thanks for reply
    What i meant was .. i want certain elements to color in the IFC export.
    Main use : rebar diameters in different colors
    Answer: not possible with Revit. IFC import export with other software.
    July 10, 2018
    India
    3
    12:32 AM
    Revit to IFC
    Quote Originally Posted by HansLammerts View Post
    Thanks for reply
    You mean IFC Import & Export with a different colour is not possible in Revit. Which software support us to complete our requirement?
    April 22, 2011
    441
    07:02 PM
    Yes, that indeed is one of the questions for getting better Exports from it.
    Here is more about that discussion from a IFC fileformat point of view. It has an open end..
    https://www.linkedin.com/groups/3690...79948039061504
  1. Custom Colors in the INI
    By GMcDowellJr in forum Architecture and General Revit Questions
    Last Post: May 17th, 2017, 08:07 PM
  2. different conduit colors
    By Ning Zhou in forum MEP - General
    Last Post: February 9th, 2017, 04:01 PM
  3. level colors
    By jpdomein in forum Structure - General Questions
    Last Post: October 9th, 2015, 07:43 AM
  4. Export to CAD with colors
    By diego1968 in forum Architecture and General Revit Questions
    Last Post: September 13th, 2012, 02:01 PM
  5. Colors and Styles
    By Munkholm in forum Forum Suggestions and Feedback
    Last Post: December 13th, 2010, 09:23 PM
