Results 1 to 6 of 6
Thread: Problem with revit structure extension 2013
    Eng
    Eng is offline
    November 6, 2015
    1
    02:33 PM
    hi
    i'm facing a big problem with revit structure 2013
    i have downloaded an extension called : revitextensionsrvt2013
    it's for auto reinforcement
    when i choose an element "for example column" then click on the reinforcement button on the structure ribbon , i get a strange error :
    i tried unistall and install again, but i still get the same problem
    February 27, 2012
    2
    03:33 PM
    same error with revit 2018 and revit 2019 naviate extension installed
    Attached Thumbnails Attached Thumbnails Problem with revit structure extension 2013-2019-02-20-4-.png
    February 27, 2012
    2
    03:33 PM
    nobody can help?
    where is the problem?
    thanks for response.
    Orlando, FL, USA
    3,096
    10:33 AM
    Quote Originally Posted by ingspiniello View Post
    nobody can help?
    Since this is about an add-in, not something that all users have, it might be difficult to get help here. I assume that the authors of the add-in have some contact information for technical support. Have you tried that?
    Coeur d Alene, ID
    4,779
    07:33 AM
    nobody can help?
    For 2019...maybe the reason it doesn't work is you cannot just copy the 2018 version and hope it works in 2019. From what I have heard the extensions that do work are pretty minimal. I'm talking about Revit Extensions... If you have the Structural Precast Extension installed, check to see if you have Update 1 installed.
    December 11, 2010
    Astana
    116
    08:33 PM
    Can you attach your file?
    Also try to leave a message about the problem via Naviate chat https://www.naviate.com/product/navi...xtension/p-660
  1. Timber Wall Extension Alignment problem
    By j_washbourne in forum Structure - General Questions
    Last Post: November 18th, 2014, 12:40 PM
  2. Roombook extension 2013 Problem
    By rhemi in forum Architecture and General Revit Questions
    Last Post: May 10th, 2014, 07:58 AM
  3. Revit 2013 - roof framing extension missing?
    By willsud in forum Architecture and General Revit Questions
    Last Post: January 17th, 2014, 12:39 PM
  4. Replies: 0
    Last Post: February 16th, 2012, 09:45 AM
  5. Revit Structure 2011 _ Extension files
    By Yan Naing Bo in forum Structure - General Questions
    Last Post: February 13th, 2012, 12:27 AM
