Results 1 to 3 of 3
Thread: ETABS - Importing Revit Model
    February 10, 2012
    7
    04:57 PM
    I am trying to find a workaround for aligning all the columns so that they are exactly at grid intersections. There are some 300+ columns and some of them are 1/100 of a millimeter off of grid line. Once this model is imported from Revit into ETABS, there is an option in ETABS to view an elevation/section at grid line 1, for example. The problem is unless the column is 100% aligned with that grid it will not show up in the view...
    Is there any way in ETABS (or Revit) to either snap those analytical nodes automatically onto grid or at least somehow highlight the columns that are offset from the grids? Anyone else ran into an issue like this? :/
    September 4, 2014
    4
    11:57 PM
    Hi sdijan,
    you can use Konstru for this. Its a software translating BIM models, you can use it to upload a Revit model and download it into Etabs. But in between you can auto-repair the model so you get a clean model to work with. Currently there are 3 repair modes when repairing a model with Konstru:
    1. Snap nodes to closest Grid, Grid, Level intersection points: this is what you are looking for, with this repair columns will snap to closest grid points.
    2. Trim or Extend to closest line: like an auto fillet operation.
    3. Project elements to closest level: this is like flatten to level.
    You can read more here
    , let me know how this works for you.
    Max
    Attached Thumbnails Attached Thumbnails ETABS - Importing Revit Model-2017-11-09_13h52_28.png
    August 21, 2018
    1
    10:57 PM
    Revit and Naviswork should deliver equally good results
    Again, you can do a little bit of research about them
    _____________
    Makosa, Hialeah
  1. CAD importing in odd location (into existing Revit model)
    By mommus in forum Architecture and General Revit Questions
    Last Post: August 18th, 2015, 10:01 AM
  2. Importing slanted wall from Architect model
    By jack.w.burnett in forum Structure - General Questions
    Last Post: June 26th, 2015, 02:26 PM
  3. Importing UB's and UC's into model
    By stryder444 in forum Structure - General Questions
    Last Post: October 28th, 2014, 09:55 PM
  4. eTABS -> Revit
    By Alex Cunningham in forum Structure - Interoperability
    Last Post: July 17th, 2012, 08:54 AM
  5. Replies: 0
    Last Post: January 20th, 2012, 10:15 AM
