Donate Now Goal amount for this year: 3000 USD, Received: 2460 USD (82%)
Results 1 to 3 of 3
Thread: Split sloping beam into 2 beams at column location
    August 15, 2012
    2
    08:12 AM
    Hi, I'm new to Revit Structures and currently on my 1st project, I'm sure I'll have many questions! I have a steel frame with sloping beams. I have a column roughly at the midpoint of my sloping beam, I'm looking to split this beam into 2 beams at the column location and have the column extend up to the top of the beam. When I use the attach column to top/base and split the beam, I can't get the beams to trim to the column correctly or for the column to extend to the top of the beams, it just stays down at the underside of the split beams.
    Can anyone advise if there is a quick way to do this?
    Thanks
    Alex Cunningham's Avatar
    December 8, 2010
    Northern California
    3,551
    11:12 PM
    First, when you attach your col to the beam it will attach to the bottom. Remove the col attaching to the beam and input the TOS for the col manually. Then re snap your beams to the top of your col. Now your col will pass by your beams and your beams will attach to the col.
    August 15, 2012
    2
    08:12 AM
    Quote Originally Posted by Alex Cunningham View Post
    Thanks for your response. This has fixed my problem. Thought there might of been a command to do this for you rather than manually inputting the levels.
  1. Beam Joins for Concrete Rectangular Beams
    By Yan Naing Bo in forum Structure - General Questions
    Last Post: February 10th, 2012, 03:25 PM
  2. Cantilevered beams and beam systems
    By kev4174 in forum Structure - General Questions
    Last Post: February 4th, 2012, 03:42 PM
  3. beam-column connection
    By r7_human8y in forum Architecture and General Revit Questions
    Last Post: November 16th, 2011, 10:18 AM
  4. Revit OpEd: Location, Location and Location
    Last Post: August 26th, 2011, 03:00 PM
  5. Beams Ending Short of Slanted Column Centerline - Help Please
    By Haymaker81 in forum Structure - General Questions
    Last Post: April 26th, 2011, 02:07 PM
