Results 1 to 2 of 2
Thread: Bolt center to center (gauge) in tag
  1.    #1
    Lurker
    June 7, 2019
    1
    05:38 PM
    I modeled a End plate connection in Revit, then took a section view (Building Section) of that so that I could add the information needed.
    I was trying to use a tag for the bolts, is there anyway for a tag to get the center to center (gauge) of the bolt pattern?
    I am not showing the gauge in my view or trying not to, I just wanted to see if I could get it with a tag, I am only showing the vertical spacing of the bolts in my view.
  2.    #2
    April 14, 2014
    66
    06:38 PM
    Quote Originally Posted by otherguy View Post
    Yes. To get this in a tag, you have to add a shared parameter in the family you are tagging, then creating a tag with a label to the shared parameter you added. It is a little involved to describe in a reply here, but not difficult. Try this Autodesk help or hit up Youtube.
    https://knowledge.autodesk.com/suppo...85988-htm.html
  1. Center Line of Family
    By dzatto in forum Architecture - Family Creation
    Last Post: October 3rd, 2018, 03:56 PM
  2. How do I rotate the arm around the center?
    By Demeter in forum Architecture - Family Creation
    Last Post: January 26th, 2016, 11:44 AM
  3. Revit OpEd: Insert using Auto-Center to Center
    Last Post: May 30th, 2014, 05:15 PM
  4. How to control center points ?
    By nguyenkien in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: April 22nd, 2014, 07:29 AM
  5. How to control center points ?
    Last Post: April 21st, 2014, 04:37 AM
