Results 1 to 3 of 3
Thread: Question about standard naming conventions for Retaining Wall footings...
  1.    #1
    Moderator LeanneZ's Avatar
    December 8, 2010
    Charlotte, NC
    762
    07:39 PM
    I started a new job about a month ago and I am not the only Revit person. :O
    So, I need to pay more attention to company "standards." Don't get me wrong, I fully appreciate company standards and promote them. I like for drawings from one company to a consistent appearance.
    We have retaining wall footings on a project I'm working on. And there are several that are the same width, but have different wall widths, heel dimensions and toe dimensions. So, I may have 3 or 4 different retaining wall footings that are all 7'-6" wide. How would you name each one to differentiate between them? My new firm doesn't have a well thought out method for differing retaining wall footings.
    In my old company, where I was the only one that needed to coordinate items like this, I would add the detail number (where the footing was detailed) to the type name; I'd use the Type Mark parameter and tag the foundations with with a tag that pulls from the Type Mark field. Not sure if this is the best way, so I'm looking to see what others are doing.
  2.    #2
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,140
    07:39 PM
    I would just add that info into the type name:
    Footing - 7' 6" - 36" Wall - 24" Toe - 30" Heel
    Footing - 7' 6" - 36" Wall - 30" Toe - 24" Heel
    It is a lot in the name, but eliminates any confusion. At least until the type changes but the name doesn't get updated (disclaimer: i'm not structural)
  3.    #3
    April 12, 2019
    11
    11:39 PM
    i agree , in order to update the names when the type change, you may use schedule by applying some filters or use dynamo to set the any parameters which you want to change
  1. Naming conventions for shared & families?
    By billiam in forum Architecture - Family Creation
    Last Post: October 29th, 2018, 05:52 PM
  2. Naming Conventions
    By lostinthe in forum Architecture and General Revit Questions
    Last Post: May 9th, 2017, 12:58 PM
  3. Replies: 9
    Last Post: January 23rd, 2017, 09:49 PM
  4. Grids naming standard
    By MB78 in forum Out There
    Last Post: September 3rd, 2015, 03:14 PM
