Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Concrete Beam / Column Clean Join
  1. #11
    April 14, 2014
    66
    10:57 AM
    Quote Originally Posted by Nurlan View Post
    This is known Revit join behavior, you can't change it (as far as I know). The floor doesn't matter here.
    Workarounds:
    Use Switch Join Order for already created beams.
    When creating a concrete beam, make it longer than the span (see Aaron screenshots), then drag the ends to the centers of columns. https://www.youtube.com/watch?v=MI1viJ8iUmI
    Thanks! I just tried this and it's not working haha, but I suspect it's like the workaround with the corners of the eccentric footings to drag them: sometimes it works and sometimes it doesn't.
    Thankfully, while architects may want all their concrete joins to be clean, this is how we should handle structures. Beams and columns are almost never poured together. We just need to make sure they are modeled properly.
    If anyone knows why Revit is installing old libraries in the new version folder, I would appreciate it.
  2. #12
    December 11, 2010
    Astana
    116
    08:57 PM
    Quote Originally Posted by Peter1979 View Post
    I think you better create a new topic on this issue.
  1. Beam to Beam or Beam to Column Join Method
    By dedo in forum Structure - General Questions
    Last Post: March 15th, 2018, 11:59 AM
  2. Concrete Beam Join Dominance
    By Patrick_Rim in forum Structure - General Questions
    Last Post: July 25th, 2017, 07:37 AM
  3. Concrete beam won't join
    By Marco79 in forum Structure - Family Creation
    Last Post: November 15th, 2016, 12:44 PM
  4. Concrete beam and column connections
    By matpog in forum Structure - General Questions
    Last Post: June 29th, 2016, 06:29 AM
  5. Concrete beam to column connection
    By ahmed_nox in forum Structure - General Questions
    Last Post: September 15th, 2014, 06:09 AM
