Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Adobe PDF Printing Issue
  1.    #1
    March 26, 2019
    9
    11:23 AM
    I am having trouble Plotting the PDF files from REVIT 2019 full version with ADOBE PDF.
    1. I tried plotting multiple sheets together and it does plotted first sheet but after that it freezes unit I end task from Task Manager.
    2. I tried plotting one by one sheets but again it is potting first sheet perfect and freezes for the second one.
    3. I looked for several solutions online and did purge my file, deleted all of the %temp% files from my computer, had low resolution for plotting but stills it's same issue for me.
    It will be really stress relieving if some one can guide me. It is very frustrating when you have to submit the drawing set to client and it takes more than 1.5 hr to just plot 15 sheets.
    Please find attached screenshot of freezing tab.
    Attached Thumbnails Attached Thumbnails Adobe PDF Printing Issue-adobe-print-issue.png
  2.    #2
    Member Darius's Avatar
    May 6, 2013
    481
    02:23 PM
    kinda more of a hack
    when u hit ctl alt+del
    go to processes running and end the acrotray and your pdf should plot but u have to baby sit it
    large numbers of sheets you may have to do this multiple times like 80 or so
    I mean 80 sheets like maybe twice on this process
    15 should only have to do this once
    it may look like u crashed but u didn't it will take a bit to come back
  3.    #3
    March 26, 2019
    9
    11:23 AM
    I did Open the task manager. I can only see Acrotray option once I end revit.
    Please find below image.
    Attached Thumbnails Attached Thumbnails Adobe PDF Printing Issue-adobe-print-issue2.png
  4.    #4
    Coeur d Alene, ID
    4,697
    11:23 AM
    Another hack is to use Ctrl+P instead of File-->Print.
    I've never had any issues, but the Ctrl+p seems to be suggested quite often.
  5.    #5
    March 26, 2019
    9
    11:23 AM
    I am using Ctrl+P still it's the same. I feel like there is something wrong with Auto desk and Adobe collaboration.
  6.    #6
    Coeur d Alene, ID
    4,697
    11:23 AM
    Are you using Adobe Acrobat or Adobe Acrobat Pro?
    You may want to try downloading PDF Creator...which is free. Also try editing the settings in Adobe to save to a specific directory instead of asking each time.
  7.    #7
    March 26, 2019
    9
    11:23 AM
    I am Using Acrobat DC. I do have path already assigned, it always asks me to confirm the file name before saving it.
    I would first want to try solving it with Adobe PDF. Still will look for PDF creator.
  8.    #8
    Senior Member biff's Avatar
    June 13, 2011
    Australia
    844
    04:23 AM
    Before you print, open one of the sheets. i.e. not on a view.
    open print and set to adobe pdf
    In adobe pdf properties turn off 'rely on system fonts only' and make your other selections like paper size and quality
    Click ok and go back to printer screen
    Set your sheet selection and all other preferences in settings etc.
    Before you print, change print range to 'current window'
    Select preview
    Preview comes up, then select top left print button on that preview and should take you back to the main printing window.
    Reselect your selected sheets button
    Print.
    All sheets should print now.
    If you want them all in one document, just watch that pesky little radio button under file that selects between multiple and seperate pdf sheet creation. It tends to flip.
    Been that way since 2016 or so.
    hope this helps, been my workaround since then.
    Still waiting on Autodesk to incorporate a PDF writer.
  9.    #9
    March 26, 2019
    9
    11:23 AM
    It WORKED!
    Thanks a ton!
  10.    #10
    June 13, 2011
    Australia
    844
    04:23 AM
    Good to hear. One good thing happens every day.
  1. PDF Printing issue
    By mhoard in forum MEP - General
    Last Post: August 16th, 2018, 03:15 PM
  2. printing issue
    By Frances91 in forum Architecture and General Revit Questions
    Last Post: July 20th, 2017, 03:28 PM
  3. Printing to Adobe Error
    By WVReviter in forum Architecture and General Revit Questions
    Last Post: August 17th, 2016, 03:18 PM
  4. Revit 2016 R2 - Adobe Printing Issue
    By mviall in forum MEP - General
    Last Post: November 4th, 2015, 11:58 AM
  5. Printing From Revit Issue
    By renogreen in forum Architecture and General Revit Questions
    Last Post: April 8th, 2015, 10:12 PM
