Results 1 to 2 of 2
Thread: Problem drawing Beam,Column connection
    Lurker
    February 1, 2019
    1
    08:11 AM
    In the picture below,i have aproblem in drawing beams
    The beams ended before column,i dont know why?
    how can i join beams to each other?
    Attached Thumbnails Attached Thumbnails Problem drawing Beam,Column connection-untitled.png
    Member Darius's Avatar
    May 6, 2013
    477
    06:11 AM
    In the modify tab there is a command to adjust beams and how they connect it looks like
    Attached Thumbnails Attached Thumbnails Problem drawing Beam,Column connection-modify-beam-column-connections.jpg
  1. Concrete beam to column connection
    By ahmed_nox in forum Structure - General Questions
    Last Post: September 15th, 2014, 06:09 AM
  2. Beam to Column Connection (RHS Sections)
    By gpktm in forum Structure - General Questions
    Last Post: October 13th, 2013, 10:14 PM
  3. Column to Beam Connection
    By gdoherty0102 in forum Structure - General Questions
    Last Post: October 24th, 2012, 12:08 PM
  4. beam-column connection
    By r7_human8y in forum Architecture and General Revit Questions
    Last Post: November 16th, 2011, 10:18 AM
  5. Stop Beam to Column Connection
    By LKeyser in forum Architecture and General Revit Questions
    Last Post: November 15th, 2011, 09:54 PM
