Results 1 to 2 of 2
Thread: View Range
    Member EarthRevi's Avatar
    August 13, 2018
    68
    08:10 AM
    View Range
    Does the view range behave the same across different disciplines? For example, I'm learning how to control the view range from an architectural tutorial by Paul Aubin on Linkedin Learning but I use a structural template. Will it still work the same? Most of the time I need to look down instead of up at the level I am framing.
    Orlando, FL, USA
    3,093
    08:10 AM
    View range has variations across different disciplines. The view direction up or down is another setting, not part of view range. Please see this other thread, for reference:
    https://www.revitforum.org/structure...tml#post214819
  1. Scope Boxes and View Range in plan view.
    By Egghead in forum Architecture and General Revit Questions
    Last Post: January 13th, 2019, 07:46 PM
  2. plan view/view range issues RCP
    By maddyjdelaney in forum Architecture and General Revit Questions
    Last Post: March 16th, 2018, 09:13 AM
  3. View Range Exceptions of Plan View
    By Pentapolis in forum Architecture and General Revit Questions
    Last Post: January 16th, 2016, 09:19 AM
  4. Revit view range - linked view
    By Grisella in forum Architecture and General Revit Questions
    Last Post: November 11th, 2014, 07:03 AM
