Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Like Tree3Likes
Thread: Dims, tags and levels falling off multi .rvt file project...
  1. #11
    December 21, 2010
    Phoenix, AZ
    2,510
    03:19 AM
    Quote Originally Posted by nikdevlin View Post
    1694 constraints to be not satisfied, 1480 elements to be unjoined, 1477 column tops below bases and 1476 cuts lost from hosts
    Sounds like the columns are the only potential limiting issue. The rest likely isn’t critical.
    Constraints means things won’t move with other things automatically. Joins are typically graphic related. Column tops below bottoms? Yeah, that could be an issue. Cuts from hosts is an issue if you need the host cut for other reasons. Some say it’s critical, others aren’t as concerned.
    Like Aaron said, it depends on where you are in the documentation process but if you’ve still got a lot of work left I’d suggest merging them and seeing how bad it really is... or isn’t.
  2. #12
    September 16, 2016
    London, UK
    15
    10:19 AM
    Yeah, but the thing is, our Project Leaders will want every single drawing checked, all 1,259 of them.
  3. #13
    December 21, 2010
    Phoenix, AZ
    2,510
    03:19 AM
    Of course!
  4. #14
    September 16, 2016
    London, UK
    15
    10:19 AM
    Confidentiality stops me from posting images of the some of the markups that we made when we did the test merge (I can't even say which project it is), suffice to say they were covered in highlighter; plans, sections, elevations, details, of the 112 we checked, there wasn't one that passed; plans were particularly bad, with some losing every single tag and dim, and dozens of copes and curtailments.
  5. #15
    9,895
    05:19 AM
    Yeah. I mean, i would 100% expect that. There should never have even been a hope or expectation that you were going to merge files and it was going to *just work.* Thats just silly.
    Merging it would be a big undertaking. Then again, its a predictable undertaking.
    Working with the trash it is now, who knows how many hours itll cost you. And you STILL need to check the drawings every time it wants to delete stuff, LOL.
  6. #16
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,886
    05:19 AM
    Re: your "column tops below bottom" problem:
    Do all of your models use the EXACT SAME Levels?
    I'm not talking just about Levels in the same place. When I said Exact, I meant EXACT.
    I've found when Binding one project into another the Levels have to
    a.) exist in all models
    b.) be at the exact same Elevation
    c.) have the exact same name
    Funky things happen when the Levels in the parent file have different names or are in a different location
  7. #17
    December 11, 2010
    Astana
    92
    04:19 PM
    I would try to consistently eliminate possible causes.
    1. Exclude the human factor. Make a copy of the project, including links that no one will change and check.
    2. Exclude add-ons. Use "clean" Revit. I have come across add-ons, which somehow influenced the model.
    3. Revit bugs. Check on latest Revit 2017.2.4. Audit & compact.
    4. Determine if a particular model causes warnings when reloading or any.
    ...subsequent steps depend on the results...
  8. #18
    September 16, 2016
    London, UK
    15
    10:19 AM
    Yep, just been in all the files and checked and all those conditions are satisfied.
    Have also been talking to our CAD support company, and as well as making sure we're all using the same build of Revit 2017, we all need to be using the same Operating System! I wouldn't have thought that would make a difference...
  1. multi leader tags
    By Darius in forum Architecture and General Revit Questions
    Last Post: March 18th, 2019, 02:26 PM
  2. Ceiling Height Tags & Split Levels
    Last Post: October 16th, 2018, 07:48 PM
  3. Shades of Grey: FALLING BEHIND
    By Shades of Grey in forum Blog Feeds
    Last Post: July 2nd, 2016, 10:45 AM
  4. Elevation Tags and Levels
    Last Post: September 28th, 2011, 02:31 PM
  5. Multi Revit File Project
    By Chowdur in forum Architecture and General Revit Questions
    Last Post: December 15th, 2010, 05:13 PM
Tags for this Thread
