Results 1 to 2 of 2
Thread: CL dimension symbol
    March 17, 2016
    2
    12:50 AM
    CL dimension symbol
    I'm using CL dimension symbols to show centre to centre dimensions on my columns.
    It works with all columns except C shaped profile ones. The family is OOTB, centreline reference planes are pinned, named, define origin... same as other column families.
    Anyone know why is that?
    Orlando, FL, USA
    3,093
    07:50 AM
    I think it is because the family is modeled so that the axis of the centroid of C section is at the vertical center reference plane of the family. That axis is always shifted to the side of the web. If you want the dimension to snap to the center of the width, you would need to put an additional reference plane in the family, weak or strong reference, at the center of the "bf" dimension.
    Attached Thumbnails Attached Thumbnails CL dimension symbol-2019-01-30_23-11-18.png
  1. Revit Dimension with Centerline Symbol Won't Recognize the Center Line of Reveals
    By Joshua Kohl in forum Architecture and General Revit Questions
    Last Post: September 4th, 2018, 03:54 PM
  2. Dimension strings not adding up to the total length dimension string (2017)
    By ledgewood33 in forum Architecture and General Revit Questions
    Last Post: March 26th, 2018, 03:24 PM
  3. Symbol/Symbol Offset for family
    By txelwood in forum MEP - Family Creation
    Last Post: April 18th, 2014, 09:28 PM
  4. Elec fixt symbol / placement ht / feed value to plan symbol label?
    By Fritz in forum Architecture - Family Creation
    Last Post: November 1st, 2013, 03:53 PM
  5. Replies: 0
    Last Post: March 6th, 2013, 10:16 PM
