Results 1 to 6 of 6
Thread: line weights
    July 9, 2017
    3
    10:38 PM
    line weights
    I'm new to Revit and am having some very basic struggles!
    I am trying to set up a template for converting CAD details to Revit and I want to have the lines visible as per the attachment.
    In the Lines drop down menu I have the options of Hidden Lines, Lines, Medium Lines and so on...
    But in: Manage/Additional Settings/Line Weights/Annotation Line Weights, I can find very specific line weights but I can's seem to apply them to a line in my drawing.
    Attached Thumbnails Attached Thumbnails line weights-line-weights-preset.jpg
    June 21, 2012
    Tours, France
    896
    10:38 AM
    Quote Originally Posted by Yoyowa View Post
    .......But in: Manage/Additional Settings/Line Weights/Annotation Line Weights, I can find very specific line weights but I can's seem to apply them to a line in my drawing.
    Hi as you already noticed it you can modify those line weights, but also you must notice that there are two more related options to lines in additional settings which are : Line styles and Line types, so in order to create your own Lines which the specific line weights you must do as follows:
    1. Go to Manage/Additional Settings Line Styles, once then you need to create your own line type or modify an existing one, but It's better to create your own! (See pic)
    2. once here you need to go to modify sub categories and hit on new:this allows you to give a name for your own line style (the name can be part of your office standards. (See Image)
    3. Doing this you'll be able to give to your line style a "Line Weight" (Which is the part you've already saw) this line weight will be affect all the lines that shared it!!
    4. You need to give to your new style a Color.
    5. the las part will be the line type Which is merely the type of representation for your line I mean, the line type represents if your lines are continue, Hidden or Dash for example, You can create your own line types if you need,
    Hope this is clear enough! if not, let me know to clarify, best regards
    Attached Thumbnails Attached Thumbnails line weights-line_styles.jpg   line weights-line_styles2.jpg   line weights-line_styles3.jpg
    July 9, 2017
    3
    10:38 PM
    Got it - thank you!
    June 21, 2012
    Tours, France
    896
    10:38 AM
    Got it - thank you!
    you're welcome!! great to know that it works!!
    January 18, 2014
    122
    03:38 AM
    In addition to the advice offered by Andres, Manage/Additional Settings/Line Weights/Annotation Line Weights does not control detail lines. Annotation Line Weights are for things like dimension string lines, section cut lines, etc. To control line weights for detail lines or model lines, use Manage/Additional Settings/Line Weights/Model Line Weights. You will need to adjust the line weight for each scale.
    Member mjajansen's Avatar
    December 26, 2011
    The Netherlands
    168
    10:38 AM
    In addition on converting CAD details to Revit details, don't use lines. Instead use detail components and don't trace over the CAD details.
  1. Line weights
    By yul in forum Dynamo BIM
    Last Post: October 17th, 2016, 01:34 PM
  2. Scaling line weights and line patterns
    By Knitro87 in forum Architecture and General Revit Questions
    Last Post: March 9th, 2016, 02:20 PM
  3. Line weights
    By blassen81 in forum MEP - General
    Last Post: June 3rd, 2014, 08:04 AM
  4. Annotation line weights
    By Shields08 in forum Architecture and General Revit Questions
    Last Post: September 6th, 2013, 11:13 PM
  5. Export Line Styles, Line Weights, and Line Patterns
    By MrBIMtastic in forum Third party Add-Ins, API and R&D
    Last Post: May 23rd, 2013, 05:36 AM
