Results 1 to 1 of 1
Thread: Tag
    September 19, 2016
    45
    09:43 AM
    Tag
    Hez,
    Another small Question in order to solve some Prasentation issues...
    I have used a Multi Rebar Annotation Tag for the floors...
    The problem is in the middle of the linier dimension lets say…
    I found a way by its Type properties in the part Equality Witness Display ,to remove the 2 middle arrows…
    There are 3 Properties there… Tick and Line Tick only and Hide….
    Is there a possibilitz to add a circe like on my pdf instead of arrows?
    Thanks again guys
    Attached Files Attached Files
