Results 1 to 1 of 1
Thread: print issue (multi)tags text cut off by view border export to dwf/dwfx
    November 15, 2016
    1
    02:08 PM
    Hi all
    I have a printing issue when exporting to dwf/dwfx. This problem does not occur when plotting to pdf.
    When I export to dwfx, the multitags text is cut off (check image 1). I literally tried all the printing options, but nothing works.
    In the second image (image 2) you can see it is not the crop view, but the border of the view which becomes visible when you hover your mouse over the view.
    Does anyone have any idea how to solve this problem? If not, can anyone show/tell me that it is possible to use multitags outside the border and export to dwfx? In that case I know it's not a Revit bug.
    Thanks in advance!
    Igor
    Attached Thumbnails Attached Thumbnails print issue (multi)tags text cut off by view border export to dwf/dwfx-1.png   print issue (multi)tags text cut off by view border export to dwf/dwfx-2.png
  1. Building Coder: Hotfix Resolves Export and Print Issue
    Last Post: May 22nd, 2017, 01:15 PM
  2. Linked text & tags showing in view.
    By Tim West in forum Architecture and General Revit Questions
    Last Post: December 21st, 2015, 02:25 AM
  3. Export to cad text wrap issue
    By diedusk in forum Architecture and General Revit Questions
    Last Post: December 16th, 2014, 07:26 PM
  4. DWG Export issue - Room tags
    By laudares in forum Architecture and General Revit Questions
    Last Post: April 29th, 2014, 08:12 PM
  5. different text color in print and plan view
    By Robin Deurloo in forum Architecture and General Revit Questions
    Last Post: August 15th, 2012, 03:20 PM
