Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By Steve_Stafford
Thread: Problem with Copy - Paste Aligned to selected Level
    January 9, 2019
    2
    10:04 PM
    Helo Everyone,Im a student and Im new in Revit, and actually i dont know where to post this so im sorry if post this thread in wrong place.
    I have a problem with copy - paste aligned to selected level
    i make a group of coloum in Level 2, and i try to Copy copy - paste aligned to selected level 3
    but the group of coloum just copied to level 2 so i got the error massage
    " There are identical instances in the same place. This will result in double counting in schedules. "
    so i figure it out that if i want to copy the coloum to level 3 i need to copy it to level 4
    so i can say the aligned level is for the top level, if i want to copy to level 4, i need to select level 5
    please help.
    Mr. Revit OpEd
    2,873
    08:04 AM
    Paste Aligned and columns are a special case > they paste "down" to the lower level, the one below the one you select. It's an old quirk they've never changed. When you choose the level, choose the level above the one you want them to go on.
    Nurlan likes this.
    January 9, 2019
    2
    10:04 PM
    Quote Originally Posted by Steve_Stafford View Post
    thank you !!
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,140
    11:04 AM
    When you place structural columns there is an option to have the column place by depth (go down) or height (go up.) When copy/pasted, the new columns keep that same orientation of down / up. At least from what I've seen.
    https://www.screencast.com/t/OfdfblmgtU
    Mr. Revit OpEd
    2,873
    08:04 AM
    Makes no difference for Copy/Paste Aligned.
  1. Groups problem: Copy/Paste (Aligned to Selected Levels)
    By rudolftopi in forum MEP - General
    Last Post: July 13th, 2018, 06:55 PM
  2. Replies: 0
    Last Post: June 6th, 2014, 04:45 AM
  3. Revit OpEd: Copy Then Paste a Level
    Last Post: July 16th, 2013, 03:15 PM
  4. Copy & Pasting using Paste Aligned to Same Place - not coming in at same place
    By cheinaranta in forum Architecture and General Revit Questions
    Last Post: June 14th, 2013, 08:32 PM
  5. Component Paste Aligned to Different Level - Ends up in Same Place
    By LKeyser in forum Architecture and General Revit Questions
    Last Post: October 1st, 2012, 06:04 PM
