Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By Alfredo Medina
Thread: Section cut in elevation and plan view
    taz
    taz is offline
    December 18, 2018
    10
    07:42 PM
    Hello,
    For a very complex project, all the panels are curved. Cutting a section through the panels on elevations will also show this section on plan view. So far so good.
    Being very curved, all the section view show unrealistic sections for the panels ( the cut being skewed, normal). Rotating the same section in plan view to cut perpendicular to the panels (to have a real section) will fix the section but it will take off the section symbol from elevation view. Is there a way to have also a symbol for section cut in elevation under these conditions(and maintaining the same section number)?
    Thanks
    Orlando, FL, USA
    3,096
    08:42 PM
    From the elevation view, start a new section view. View > Section... but before clicking any points on the screen, activate "Reference another view", then select the first section view from the list. Then, proceed to click to define the two points that define the reference section.
    Dave Jones likes this.
    taz
    taz is offline
    December 18, 2018
    10
    07:42 PM
    Super. It worked perfect.
    Thanks a lot !!!
  1. Replies: 9
    Last Post: July 25th, 2018, 03:48 PM
  2. Different elevation points in section and plan
    By jgardner in forum Architecture and General Revit Questions
    Last Post: September 2nd, 2016, 08:07 PM
  3. Copying Symbolic Lines From a Plan View to an Elevation View??
    By Legoboy in forum Architecture and General Revit Questions
    Last Post: December 23rd, 2015, 04:09 PM
  4. Changing the Plan and Section/Elevation Representation of trees?
    By gooner442 in forum Architecture and General Revit Questions
    Last Post: December 9th, 2014, 09:24 AM
  5. How to view Section view lines on a plan view bigger than 1:100 scale
    By eks_al in forum Architecture and General Revit Questions
    Last Post: January 17th, 2012, 11:41 PM
