Results 1 to 3 of 3
Thread: Callout section label
    October 17, 2018
    68
    02:52 PM
    Hello to everyone,
    I am at the moment trying to understand why is the callout section head rectangular or where can I change that. You can checa the section head of the callout in the picture that I am uploading. Also, I would like to know why the callout donīt show at the left menu of the project browser? the first picture, that show the section head of the callout is named "callout.png" and the second picture is called "project browser callout".
    Attached Thumbnails Attached Thumbnails Callout section label-callout.png   Callout section label-project-browser-callout.jpg
    jmk
    jmk is offline
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,398
    08:52 AM
    The corners are squared off until the callout reaches a size that Revit can accommodate the specified corner radius. Either make your callout larger, or reduce the radius of the corners for that type of callout.
    As for why it isn't in the project browser, start by checking your project browser settings.
    Member d.stairmand's Avatar
    February 24, 2011
    Auckland
    336
    03:52 AM
    Quote Originally Posted by ppatricio View Post
    Hello to everyone,
    The Callout Head is a Symbol Family. You can change this to a Round one if required.
    Select the Callout, and then Go into it Properties. Go into its Callout Head Parameter & see what family it is point too. Edit this family or Adjust it to another Family.
    Let us know your Outcome please!
  1. Replies: 6
    Last Post: July 9th, 2018, 04:59 PM
  2. Position Section Label
    By Andyrh82 in forum Architecture and General Revit Questions
    Last Post: November 21st, 2017, 03:31 PM
  3. Revit section/callout not functioning correctly
    By Lucifer in forum Structure - General Questions
    Last Post: April 20th, 2016, 01:05 PM
  4. Section / Callout Heads are Orange
    By Chadwick17 in forum Architecture and General Revit Questions
    Last Post: March 9th, 2013, 06:22 PM
  5. 3/4" section callout
    By Tom Dolle in forum Architecture and General Revit Questions
    Last Post: October 9th, 2012, 08:19 PM
