Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By Alfredo Medina
Thread: Steel tonnage shedule in Revit 2019
    November 18, 2018
    2
    12:36 AM
    Hi everyone,
    I am working on a project that requires steel tonnage schedule (using Revit 2019). I am totally lost. I need help
    Mr. Revit OpEd
    2,873
    05:36 PM
    The steel shapes that you use can be scheduled and their W parameter represents their weight per foot (imperial assumption). The metric content has their metric weight. Schedules are most effective when they are focused on individual categories, like Structural Framing versus Columns. You'll also need to filter out other materials like concrete if you have that type too. The results can give you the total for framing and another total for columns and combined gives you the overall number. There are other categories for connections and such if you're trying to dig deeper into miscellaneous metal fabrication.
    November 18, 2018
    2
    12:36 AM
    Steel tonnage
    Quote Originally Posted by Steve_Stafford View Post
    Thank you for your response. In Revit 2019, there is no W parameter. I have attached the steel properties for your attention. I am confused on how to generate formula for tonnage from the attached properties. Thank you
    Attached Files Attached Files
    Mr. Revit OpEd
    2,873
    05:36 PM
    Sorry. I thought they'd plugged this hole. Must be most everyone already has the workaround built in to their templates now. The trick is to add a shared parameter to map the built in W parameter (column and framing) to one that can be used in a schedule, read their article explaining it.
    Orlando, FL, USA
    3,096
    08:36 PM
    Another alternative, without having to open families, is to use schedules, based on the Volume property of structural members.
    For example, for metric units:
    Attached Thumbnails Attached Thumbnails Steel tonnage shedule in Revit 2019-2018-12-21_8-53-18.jpg
    d.stairmand likes this.
  1. Revit 2019 steel tab
    By Brocha in forum Structure - General Questions
    Last Post: September 12th, 2018, 03:28 PM
  2. Steel Tonnage Takeoff - Isolated Section
    By kev4174 in forum Structure - General Questions
    Last Post: July 17th, 2016, 01:10 AM
  3. Revit Steel Tonnage
    By akaplan in forum Structure - General Questions
    Last Post: June 14th, 2016, 02:50 PM
  4. Steel material tonnage in schedule
    By Clara2011 in forum Structure - General Questions
    Last Post: March 7th, 2013, 05:40 PM
  5. Steel tonnage cautions
    By Alfredo Medina in forum Structure - General Questions
    Last Post: September 28th, 2011, 06:23 AM
