Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: grids dont appear at the foundation level
    October 17, 2018
    68
    11:14 PM
    hello to everyone,
    I would like to know why the grids ain´t showing at the foundation level... I have the grids extended throught them as you can throught the elevation. See picture above.
    best regards
    Attached Thumbnails Attached Thumbnails grids dont appear at the foundation level-grids-ain%B4t-showing-foundation-level....jpg
    Mr. Revit OpEd
    2,772
    03:14 PM
    Their 3D extent must cross over the level to show up. Most likely their 2D extent does but the 3D is above that level.
    October 17, 2018
    68
    11:14 PM
    I think that you are not correct, becuase as you can see throught the picture, the grids are extendend throught the foundations and at the end of the line you can see the 3D mark. The following link shows what I am saying:
    Best regards
    Coeur d Alene, ID
    4,591
    03:14 PM
    category turned off? workset turned off? Someone selected all and hid them?
    Mr. Revit OpEd
    2,772
    03:14 PM
    Quote Originally Posted by ppatricio
    I think that you are not correct...
    What I wrote is factually correct, but the patient is still dead. Your circumstance just means something else is preventing them from being visible. I started with the fundamental one, if the extents don't cross, no grids. Are you familiar with this thread/check list?
    October 17, 2018
    68
    11:14 PM
    Ok, sorry for my ignorance, but assuming that the problem is the fact that the 2d extent cross the foundation level, but the 3d extent dont, how can i see or set the 3d extent to cross the foundation level. My problem is that I thought that i only had to extent the grids until tey cross the levels in the elevation in order to show in the blueprints.
    Best regards
    Mr. Revit OpEd
    2,772
    03:14 PM
    There are many ways to hide elements. The link I provided earlier is a checklist of sorts that might help narrow down the issue in your case. Go to the first post in the thread or you can read my own list HERE.
    October 17, 2018
    68
    11:14 PM
    @Steve_Stafford, I am sorry but in the website that you gave me it doesn´t show any topic about hidden grids... I would really appreciate if you could help me in this subject since, as you may see throught the picture that I am uploading in this link, it seems that the 3d extents cross over the foundations, or am I wrong?
    Also, as you may see throught the picture that I am uploading in the following link:
    best regards, in the visibility graphics overrides, you can see that the grids are ticked, so they are active.
    Coeur d Alene, ID
    4,591
    03:14 PM
    Click the light bulb when the view is open...see if you can see them there.
    October 17, 2018
    68
    11:14 PM
    You are refering to the bulb that is responsible to show hidden and unhidden elements?
  1. Foundation aint changing the height offset from the level
    By ppatricio in forum Structure - General Questions
    Last Post: November 2nd, 2018, 10:18 AM
  2. Foundation and slab tag that calculates over excavation level
    By Erchprime in forum Architecture and General Revit Questions
    Last Post: March 28th, 2018, 06:19 PM
  3. Making the level of the bottom of the foundations the same for ever foundation
    By WorldDue in forum Structure - General Questions
    Last Post: December 10th, 2017, 08:36 AM
  4. Top of Foundation tags ... absolute/ relative to sea level?
    By LeanneZ in forum Structure - General Questions
    Last Post: July 5th, 2017, 02:37 PM
  5. Multiple Level Foundation Plans
    Last Post: August 10th, 2011, 03:32 PM
