Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: grids dont appear at the foundation level
  1. #11
    Coeur d Alene, ID
    4,744
    04:48 AM
    Yes....also check to see if you have any filters enabled since your view has a view template enabled.
  2. #12
    October 17, 2018
    68
    11:48 AM
    @MPwuzhere, the grids are hidden, but I do not knwo why.... I cant unhide them as you can see throught the picture that I am uploading...the link is this one:
    best regards
    PS: Actually the grids that are shown in here, are provided from an imported link... so the problem stands....
  3. #13
    Coeur d Alene, ID
    4,744
    04:48 AM
    Um...did you check the filters?
    Last edited by MPwuzhere; December 6th, 2018 at 03:42 PM. Reason: it was the plan...oops
  1. Foundation aint changing the height offset from the level
    By ppatricio in forum Structure - General Questions
    Last Post: November 2nd, 2018, 10:18 AM
  2. Foundation and slab tag that calculates over excavation level
    By Erchprime in forum Architecture and General Revit Questions
    Last Post: March 28th, 2018, 06:19 PM
  3. Making the level of the bottom of the foundations the same for ever foundation
    By WorldDue in forum Structure - General Questions
    Last Post: December 10th, 2017, 07:36 AM
  4. Top of Foundation tags ... absolute/ relative to sea level?
    By LeanneZ in forum Structure - General Questions
    Last Post: July 5th, 2017, 02:37 PM
  5. Multiple Level Foundation Plans
    Last Post: August 10th, 2011, 03:32 PM
