Results 1 to 2 of 2
Thread: slab on the pheripheral beam
    October 17, 2018
    68
    03:05 PM
    Hello to everyone,
    I am doing my first project on revit, and I was woundering where can I put the lines that limit the geometry of the slab. In s ituation that I have two slabs in which one of their lines intersect, I draw the lines througth the middle of the element in which they are, beams... But in a situation like this... more precisely, a case where aI have a beam that goes throught a beam that is alligned peripherally, I think that the best way is to model this elemnt through th exterior face of the beam, Am I correct? I want to know about this because I would like to have a model that can be used to structural analysis. To better understanding of what I am talking I am uploading a photo that represent this type of situation.
    Best regards
    peripherally
    Attached Thumbnails Attached Thumbnails slab on the pheripheral beam-modelling-slabs.jpg
    Orlando, FL, USA
    3,025
    11:05 AM
    Think of the boundary that the builders need to define at the construction site to pour this slab. "Model it as you build it".
  1. sloped beam under slab
    By ppatricio in forum Structure - General Questions
    Last Post: December 18th, 2018, 09:58 PM
  2. beam under the slab
    Last Post: November 16th, 2018, 03:52 PM
  3. Slab and Beam volume
    By Drew in forum Structure - General Questions
    Last Post: November 13th, 2015, 10:11 PM
  4. Beam system join to slab
    By redmonki in forum Architecture and General Revit Questions
    Last Post: July 16th, 2013, 03:21 AM
  5. beam and slab
    By huyxp in forum Structure - General Questions
    Last Post: July 1st, 2013, 08:38 AM
