Results 1 to 2 of 2
Thread: Plastering for structural columns and beams
    October 8, 2018
    1
    04:45 PM
    Hi Everyone,
    I am facing a problem in applying plastering to columns, beams and lintels. Using a plugin named "skirting board" i was able to overcome plastering issue for columns, But still failed to apply the same for beams. PFA image for better understanding. I would be glad if anyone can suggest me a way to apply and calculate plaster for structual elements.
    Thanks in Advance
    Attached Thumbnails Attached Thumbnails Plastering for structural columns and beams-plaster-issue.png
    Orlando, FL, USA
    3,093
    07:15 AM
    Welcome to Revitforum. Late reply but better late than never.
    This is difficult. If you model the plaster, that is very time consuming and tedious. If you paint faces of beams that would be faster and accurate. But you won't see the plaster as an object with thickness in your sections, but you could indicate that in details. I would paint faces and then use a material take-off schedule to get quantities.
  1. Cant load structural beams and columns..
    By boriskam1991 in forum Architecture and General Revit Questions
    Last Post: January 29th, 2019, 12:22 AM
  2. Family with several beams and columns
    By Harnta in forum Structure - Family Creation
    Last Post: January 17th, 2019, 12:17 PM
  3. columns and beams not showing in section
    By joewallace in forum Architecture and General Revit Questions
    Last Post: May 4th, 2013, 09:53 PM
  4. Beams & columns
    By narlee in forum Architecture and General Revit Questions
    Last Post: April 22nd, 2012, 08:10 PM
  5. OOTB Content for Beams/Columns
    By TheViking in forum Structure - General Questions
    Last Post: May 7th, 2011, 04:57 AM
